Hermes: a simple and efficient algorithm for building the AOC-poset of a binary relation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Mathematics and Artificial Intelligence Année : 2014
Given a relation $\Rel\subseteq\Obj\times\Attr$ on a set $\Obj$ of objects and a set $\Attr $ of attributes, the AOC-poset (Attribute/Object Concept poset), is the partial order defined on the ``introducers'' of objects and attributes in the corresponding concept lattice. In this paper, we present \hermes, a simple and efficient algorithm for building an AOC-poset which runs in $O(min\{nm,\,n^\alpha\})$, where $n$ is the number of objects and attributes, $m$ is the size of the relation, and $n^\alpha$ is the time required to perform matrix multiplication (currently $\alpha=2.376$). Finally, we compare the execution time of \hermes~with the execution time of other published algorithms which compute the AOC-poset: \ares, \ceres~and \pluton. We characterize the cases where each of these algorithms is relevant to use.
berry-etal-amai72-2014 (1).pdf (669.37 Ko) Télécharger le fichier
hal-01101144 , version 1 (09-01-2015)
Anne Berry, Alain Gutierrez, Marianne Huchard, Amedeo Napoli, Alain Sigayret. Hermes: a simple and efficient algorithm for building the AOC-poset of a binary relation. Annals of Mathematics and Artificial Intelligence, 2014, 72 (1), pp.45-71. ⟨10.1007/s10472-014-9418-6⟩. ⟨hal-01101144⟩
460 Consultations
933 Téléchargements
