Distributed Coordination of Self-Organizing Mechanisms in Communication Networks - Archive ouverte HAL Access content directly
Journal Articles IEEE Transactions on Control of Network Systems Year : 2014
(1) , (2) , (1) , (3)
1
2
3
The fast development of the Self-Organizing Network (SON) technology in mobile networks renders critical the problem of coordinating SON functionalities operating simultaneously. SON functionalities can be viewed as control loops that may need to be coordinated to guarantee conflict free operation, to enforce stability of the network and to achieve performance gain. This paper proposes a distributed solution for coordinating SON functionalities. It uses Rosen's concave games framework in conjunction with convex optimization. The SON functionalities are modeled as linear Ordinary Differential Equation (ODE)s. The stability of the system is first evaluated using a basic control theory approach. The coordination solution consists in finding a linear map (called coordination matrix) that stabilizes the system of SON functionalities. It is proven that the solution remains valid in a noisy environment using Stochastic Approximation. A practical example involving three different SON functionalities deployed in Base Stations (BSs) of a Long Term Evolution (LTE) network demonstrates the usefulness of the proposed method.
tall.pdf (672.43 Ko) Télécharger le fichier
Dates and versions
hal-01101202 , version 1 (08-01-2015)
Identifiers
Cite
Abdoulaye Tall, Richard Combes, Zwi Altman, Eitan Altman. Distributed Coordination of Self-Organizing Mechanisms in Communication Networks. IEEE Transactions on Control of Network Systems, 2014, 1 (4), pp.328-337. ⟨10.1109/TCNS.2014.2357511⟩. ⟨hal-01101202⟩
157 View
162 Download
Share
