New interface
Reports (Technical report)
Design and Implementation of rowe, a Web-Friendly Communication Library
Abstract : The INDES project-team of Inria has been developing HOP, a multi-tier language for Web programming. As part of the RAPP FP7 European project, the team has set out to use HOP as the lingua franca of the robotics applications developed within that project. Part of the challenge lies in the integration of existing robotics code, written using ROS or custom libraries, with HOP-based application. This document reports on the implementation of rowe, a communication library designed the fill the gap between low-level robotics C components on one hand, and other C, C++, ROS, or HOP components on the other. The library aims to be a lightweight, high-performance, ``Web-friendly'' communication library. It implements a socket-like interface that allows programs to exchange JSON objects over WebSockets. We describe the rationale, design, and implementation of rowe.
Document type :
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/hal-01101660
Contributor : Ludovic Courtès Connect in order to contact the contributor
Submitted on : Friday, January 9, 2015 - 11:40:04 AM
Last modification on : Wednesday, October 26, 2022 - 8:13:55 AM
Long-term archiving on: : Friday, April 10, 2015 - 10:35:22 AM
RT-452.pdf
Distributed under a Creative Commons Attribution - ShareAlike 4.0 International License
Identifiers
  • HAL Id : hal-01101660, version 1
  • ARXIV : 1501.02162
Collections
Citation
Ludovic Courtès. Design and Implementation of rowe, a Web-Friendly Communication Library. [Technical Report] RT-0452, Inria Bordeaux Sud-Ouest; INRIA. 2015, pp.10. ⟨hal-01101660⟩
Share
Metrics
Record views
264
Files downloads
75
