Efficient OLAP Operations for RDF Analytics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
Opérations OLAP efficace pour l'analyse de données RDF
RDF is the leading data model for the Semantic Web, and dedicated query languages such as SPARQL 1.1, featuring in particular aggregation, allow extracting information from RDF graphs. A framework for analytical processing of RDF data was introduced in [1], where analytical schemas and analytical queries (cubes) are fully re-designed for heterogeneous, semantic-rich RDF graphs. In this novel analytical setting, we consider the following optimization problem: how to reuse the materialized result of a given analytical query (cube) in order to compute the answer to another analytical query obtained through a typical OLAP operation. We provide view-based rewriting algorithms for these query transformations, and demonstrate experimentally their practical interest.
RR-8668.pdf (1.12 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01101843 , version 1 (09-01-2015)
  • HAL Id : hal-01101843 , version 1
Elham Akbari Azirani, François Goasdoué, Ioana Manolescu, Alexandra Roatis. Efficient OLAP Operations for RDF Analytics. [Research Report] RR-8668, OAK team, Inria Saclay; INRIA. 2015. ⟨hal-01101843⟩
330 Consultations
484 Téléchargements
