Geometric conservation laws for flow problems with moving boundaries and deformable meshes, and their impact on aeroelastic computations, Computer Methods in Applied Mechanics and Engineering, vol.134, issue.1-2, pp.71-90, 1996. ,
DOI : 10.1016/0045-7825(96)01028-6
Construction and analysis of compact residual discretizations for conservation laws on unstructured meshes, 2005. ,
A multidimensional upwind discretization method for the Euler equations on unstructured grids, 1994. ,
An Interpolation Free Two-Dimensional Conservative ALE scheme over Adaptive Unstructured Grids for Rotorcraf Aerodynamics ,
An unstructured node-centered finite volume scheme for shallow water flows with wet/dry fronts over complex topography, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.47-48, pp.3723-3750, 2009. ,
DOI : 10.1016/j.cma.2009.08.006
High-resolution methods In Finite Volume Methods for Hyperbolic problems, p.107, 2004. ,
An ALE Formulation for Explicit Runge???Kutta Residual Distribution, Journal of Scientific Computing, vol.215, issue.1, pp.1467-1482, 2014. ,
DOI : 10.1007/s10915-014-9910-5
URL : https://hal.archives-ouvertes.fr/hal-01087947
Explicit Runge???Kutta residual distribution schemes for time dependent problems: Second order case, Journal of Computational Physics, vol.229, issue.16, pp.5653-5691, 2010. ,
DOI : 10.1016/j.jcp.2010.04.002
URL : https://hal.archives-ouvertes.fr/inria-00406958
Fundamental concepts and approaches, Hanbook of Grid Generation, p.10, 1999. ,
Numerical solution of the quasilinear poisson equation in a nonuniform triangle mesh, Journal of Computational Physics, vol.1, issue.2, pp.149-172, 1967. ,
DOI : 10.1016/0021-9991(66)90001-5
Elliptic Generation Systems, Hanbook of Grid Generation, p.5, 1999. ,
DOI : 10.1201/9781420050349.ch4
Second-Order Accurate Godunov Scheme for??Multicomponent Flows on Moving Triangular Meshes, Journal of Scientific Computing, vol.1, issue.1, pp.64-86, 2008. ,
DOI : 10.1007/s10915-007-9162-8
Multidimensional upwinding for grid adaptation. Numerical Methods for Wave Propagation, pp.33-54, 1998. ,
Adaptive Mesh Methods for One- and Two-Dimensional Hyperbolic Conservation Laws, SIAM Journal on Numerical Analysis, vol.41, issue.2, pp.487-515, 2003. ,
DOI : 10.1137/S003614290138437X
Anr-Adaptive Finite Element Method Based upon Moving Mesh PDEs, Journal of Computational Physics, vol.149, issue.2, pp.221-244, 1998. ,
DOI : 10.1006/jcph.1998.6151
The finite element method with Lagrangian multipliers, Numerische Mathematik, vol.12, issue.3, pp.179-19273, 1972. ,
DOI : 10.1007/BF01436561
A Moving Mesh Finite Element Algorithm for Singular Problems in Two and Three Space Dimensions, Journal of Computational Physics, vol.177, issue.2, pp.365-393, 2002. ,
DOI : 10.1006/jcph.2002.7002
Quadratic Programming, Numerical Optimization, chapter 16, p.439, 1999. ,
DOI : 10.1007/0-387-22742-3_16
