A type-logical account of quantification in event semantics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
It has been argued that Davidson's event semantics does not combine smoothly with Montague's compositional semantics. The difficulty, which we call the event quantification problem, comes from a possibly bad interaction between event existential closure, on the one hand, and quantification, negation, or conjunction, on the other hand. The re-cent literature provides two solutions to this problem. The first one is due to Champollion, and the second one to Winter and Zwarts. The present paper elaborates on this second solution. In particular, it provides a treatment of quantified adverbial modifiers, which was absent from Winter and Zwarts.
deGroote_Winter.pdf (257.73 Ko) Télécharger le fichier
hal-01102261 , version 1 (12-01-2015)
  • HAL Id : hal-01102261 , version 1
Philippe de Groote, Yoad Winter. A type-logical account of quantification in event semantics. Logic and Engineering of Natural Language Semantics 11, Nov 2014, Tokyo, Japan. ⟨hal-01102261⟩
932 Consultations
291 Téléchargements
