Journal articles
Constant Modulus Algorithms Using Hyperbolic Givens Rotations
Abstract : We propose two new algorithms to minimize the constant modulus (CM) criterion in the context of blind source separation. The first algorithm, referred to as Givens CMA (G-CMA) uses unitary Givens rotations and proceeds in two stages: prewhitening step, which reduces the channel matrix to a unitary one followed by a separation step where the resulting unitary matrix is computed using Givens rotations by minimizing the CM criterion. However, for small sample sizes, the prewhitening does not make the channel matrix close enough to unitary and hence applying Givens rotations alone does not provide satisfactory performance. To remediate to this problem, we propose to use non-unitary Shear (Hyperbolic) rotations in conjunction with Givens rotations. This second algorithm referred to as Hyperbolic G-CMA (HG-CMA) is shown to outperform the G-CMA as well as the Analytical CMA (ACMA) in terms of separation quality. The last part of this paper is dedicated to an efficient adaptive implementation of the HG-CMA and to performance assessment through numerical experiments.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01102907
Contributor : Karim Abed-Meraim Connect in order to contact the contributor
Submitted on : Tuesday, January 13, 2015 - 4:36:42 PM
Last modification on : Saturday, June 25, 2022 - 10:12:42 AM
Identifiers
  • HAL Id : hal-01102907, version 1
Collections
Citation
Aissa Ikhlef, R. Iferroujene, Abdelwaheb Boudjellal, Karim Abed-Meraim, Adel Belouchrani. Constant Modulus Algorithms Using Hyperbolic Givens Rotations. Elsevier Signal Processing Journal, 2014, pp.12. ⟨hal-01102907⟩
Share
Metrics
Record views
31
