Convergence and error analysis for a class of splitting schemes in incompressible fluid-structure interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2016
This paper is devoted to the convergence analysis of the generalized Robin-Neumann schemes introduced in [Internat. J. Numer. Methods Engrg., 101(3):199–229, 2015] for the coupling of a viscous incompressible fluid with a thick-walled elastic or viscoelastic structure. To this purpose, a representative linearized setting is considered. The methods are formulated within a class of operator splitting schemes which treat implicitly the coupling between the fluid and the solid inertia contributions. This guarantees energy stability. A priori error estimates are derived for all the explicit and semi-implicit variants. The analysis predicts a non-uniformity in space of the splitting error, hence confirming the numerical evidence of [Internat. J. Numer. Methods Engrg., 101(3):199–229, 2015] for the explicit variants. Besides, the analysis demonstrates that the genesis of this accuracy loss is the spatial non-uniformity of the discrete elastic or viscoelastic solid operator. The theoretical findings are illustrated via a numerical study which shows, in particular, that alternative splitting schemes recently reported in the literature also suffer from these accuracy issues.
RR-8670 (1).pdf (921.31 Ko) Télécharger le fichier
hal-01102975 , version 1 (13-01-2015)
hal-01102975 , version 2 (14-01-2015)
hal-01102975 , version 3 (23-10-2015)
Miguel Angel Fernández, Jimmy Mullaert. Convergence and error analysis for a class of splitting schemes in incompressible fluid-structure interaction. IMA Journal of Numerical Analysis, 2016, 36 (4), pp.1748-1782. ⟨10.1093/imanum/drv055⟩. ⟨hal-01102975v3⟩
395 Consultations
363 Téléchargements
