New interface
Reports (Technical report)
Automatic Deployment of Software Components in the Cloud with the Aeolus Blender
Abstract : Cloud computing allows to build sophisticated software sys-tems on virtualized infrastructures at a fraction of the cost that was necessary just a few years ago. The deployment of such complex systems, though, is still a serious issue due to the need of deploying a large number of packages and services, their elaborated interdependencies, and the need to define the (ideally optimal) allocation of software compo-nents onto available computing resources. In this paper we present the Aeolus Blender (Blender in the following), a toolchain that automates the assembly and deployment of complex component-based software systems in the "cloud". By relying on a configuration optimizer and a deployment planner, Blender fully automates the deploy-ment of real-life cloud applications on OpenStack infrastruc-tures, by exploiting a knowledge base of software compo-nents defined in the Mandriva Armonic tool-suite. The final deployment is guaranteed to satisfy not only user require-ments and software dependencies, but also to be optimal with respect to the number of used virtual machines.
Document type :
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01103806
Contributor : Jacopo Mauro Connect in order to contact the contributor
Submitted on : Thursday, January 15, 2015 - 2:14:43 PM
Last modification on : Wednesday, October 26, 2022 - 8:13:55 AM
Long-term archiving on: : Saturday, September 12, 2015 - 6:28:06 AM
File
main.pdf
Identifiers
  • HAL Id : hal-01103806, version 1
Citation
Roberto Di Cosmo, Antoine Eiche, Jacopo Mauro, Gianluigi Zavattaro, Stefano Zacchiroli, et al.. Automatic Deployment of Software Components in the Cloud with the Aeolus Blender. [Technical Report] Inria Sophia Antipolis. 2015. ⟨hal-01103806⟩
Share
Metrics
Record views
398
Files downloads
359
