Audio source localization by optimal control of a mobile robot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the task of audio source localization using a mi-crophone array on a mobile robot. Active localization algo-rithms have been proposed in the literature that can estimate the 3D position of a source by fusing the measurements taken for different poses of the robot. The robot movements are typ-ically fixed, however, or they obey heuristic strategies, such as turning the head and moving towards the source, which may be suboptimal. In this paper, we propose to control the robot movements so as to locate the source as quickly as possible. We represent the belief about the source position by a discrete grid and we introduce a dynamic programming algorithm to find the optimal robot motion minimizing the entropy of the grid. We report initial results in a real environment.
vincent_ICASSP15.pdf (224.51 Ko) Télécharger le fichier
hal-01103949 , version 1 (15-01-2015)
hal-01103949 , version 2 (24-09-2016)
  • HAL Id : hal-01103949 , version 2
Emmanuel Vincent, Aghilas Sini, François Charpillet. Audio source localization by optimal control of a mobile robot. IEEE 2015 International Conference on Acoustics, Speech and Signal Processing (ICASSP), Apr 2015, Brisbane, Australia. ⟨hal-01103949v2⟩
465 Consultations
629 Téléchargements
