Conference papers
Residual energy-based transmission schemes for event reporting wireless sensor networks
Carlos A. Guzmán-Medina 1 Mario E. Rivero-Angeles 2, 1 Gerardo Rubino 2
2 DIONYSOS - Dependability Interoperability and perfOrmance aNalYsiS Of networkS
Inria Rennes – Bretagne Atlantique , IRISA-D2 - RÉSEAUX, TÉLÉCOMMUNICATION ET SERVICES
Abstract : WSNs are complex systems that are mainly limited by the battery life of the nodes in order to have an adequate performance. In most cases, it is possible to have a re-deployment of new nodes in order to prolong the systems lifetime. This leads to a situation where some nodes have a low energy level while other nodes (the majority of nodes instants after the re-deployment procedure) have high energy levels. In this environments, it is clear that ancient nodes, those with low energy level, have to contend for the shared medium against the majority of high energy nodes. As such, the remaining battery life of low energy nodes would be rapidly consumed. In this paper, we propose to extend the battery life of low energy nodes by means of assigning prioritized access to the shared channel to those nodes in order to content among a low population of such nodes, while delaying the contention access of high energy nodes which can support higher number of collisions before energy depletion. This is done by studying two different transmission strategies referred to as “hard” and “soft” transmission probabilities. Results show that, a soft transmission strategy achieves better results in terms of reduced energy consumption than both the conventional protocol or a hard transmission assignment.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01104535
Contributor : Yassine Hadjadj Aoul Connect in order to contact the contributor
Submitted on : Friday, January 16, 2015 - 10:43:22 PM
Last modification on : Thursday, January 20, 2022 - 4:20:24 PM
Identifiers
Citation
Carlos A. Guzmán-Medina, Mario E. Rivero-Angeles, Gerardo Rubino. Residual energy-based transmission schemes for event reporting wireless sensor networks. 11th International Symposium on Wireless Communications Systems (ISWCS 2014), Aug 2014, Barcelona, Spain. pp.95-99, ⟨10.1109/ISWCS.2014.6933327⟩. ⟨hal-01104535⟩
Share
Metrics
Record views
189
