New interface
Reports (Research report)
Uniqueness results for 2D inverse Robin problems with bounded coefficient
Laurent Baratchart 1 Laurent Bourgeois 2 Juliette Leblond 1
2 POEMS - Propagation des Ondes : Étude Mathématique et Simulation
Inria Saclay - Ile de France, UMA - Unité de Mathématiques Appliquées, CNRS - Centre National de la Recherche Scientifique : UMR7231
Abstract : We address in this work the uniqueness issue in the classical Robin inverse problem with the Laplace equation on a Dini-smooth planar domain, with uniformly bounded Robin coefficient and L2 Neumann data. We prove uniqueness of the Robin coefficient on a subpart of the boundary, given Cauchy data on the complementary part.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01104629
Contributor : Juliette Leblond Connect in order to contact the contributor
Submitted on : Sunday, January 18, 2015 - 4:52:18 PM
Last modification on : Wednesday, October 26, 2022 - 8:15:22 AM
Long-term archiving on: : Friday, September 11, 2015 - 6:44:17 AM
File
RR-v2-2.pdf
Identifiers
  • HAL Id : hal-01104629, version 1
Citation
Laurent Baratchart, Laurent Bourgeois, Juliette Leblond. Uniqueness results for 2D inverse Robin problems with bounded coefficient. [Research Report] RR-8665, INRIA Sophia Antipolis; INRIA Saclay; INRIA. 2015. ⟨hal-01104629⟩
Share
Metrics
Record views
316
Files downloads
78
