Abstract : Column generation is a well-known method to solve large-scale combinatorial optimisation problem. However, its application in practice if often limited by convergence issues. To overcome this drawback, several stabilization techniques have been proposed. Probably, the most common techniques are 1) adding piecewise linear penalty functions to the dual objective and 2) dual price smoothing, which consists in pricing with a linear combination of the current dual solution and the best dual solution obtained earlier. Recently we proposed an automatic (parameter-less) variant of the dual price smoothing technique.
In this work, we experimentally compare efficiency of the two mentioned stabilisation techniques on a wide range of problems, including machine scheduling, generalised assignment, lot sizing, capacitated vehicle routing, shift scheduling, and min-cost multi-commodity flow. Then, we also test numerically the combination of these techniques. Our experimental results show that for most problems this combination outperforms the two techniques applied separately.
