New high order sufficient conditions for configuration tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2015
In this paper, we propose new conditions guaranteeing that the trajectories of a mechanical control system can track any curve on the configuration manifold. We focus on systems that can be represented as forced affine connection control systems and we generalize the sufficient conditions for tracking known in the literature. The new results are proved by a combination of averaging procedures by highly oscillating controls with the notion of kinematic reduction.
hal-01105126 , version 1 (19-01-2015)
M. Barbero-Liñán, M. Sigalotti. New high order sufficient conditions for configuration tracking. Automatica, 2015, 62, pp.222-226. ⟨10.1016/j.automatica.2015.09.032⟩. ⟨hal-01105126⟩
110 Consultations
0 Téléchargements
