Sylvester's identity and multistep integer-preserving Gaussian elimination, Math. of Comput, vol.22, pp.565-578, 1968. ,
A bound on the minimum of the real positive polynomial over the standard simplex, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00350115
Algorithms in Real Algebraic Geometry, Algorithms & Comput. in Math, vol.10, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01083587
The number of roots of a system of equations, Funct. Anal. and Appl, vol.9, pp.183-185, 1975. ,
A new principle in the geometry of numbers, with some applications, Trans. AMS, vol.15, pp.227-235, 1914. ,
Lower bounds for zero-dimensional projections, Proc. Annual ACM Symp. on Symbolic and Algebraic Computation (ISSAC), 2009. ,
Complete subdivision algorithms, II: Isotopic meshing of singular algebraic curves, Proc. 33th ACM Int'l Symp. on Symbolic & Algebraic Comp. (ISSAC), pp.87-94, 2008. ,
Generalised characteristic polynomials, J. Symbolic Computation, vol.9, pp.241-250, 1990. ,
The Complexity of Robot Motion Planning, ACM Doctoral Dissertation Award Series, 1987. ,
A subdivision-based algorithm for the sparse resultant, J. ACM, vol.47, pp.417-451, 2000. ,
Using Algebraic Geometry. Number 185 in GTM, 2005. ,
Computing sparse projection operators, Symbolic Computation: Solving Equations in Algebra, Geometry, & Engineering, vol.286, pp.121-140, 2001. ,
Heights of varieties in multiprojective spaces and arithmetic nullstellensatze, Annales Scientifiques de l'ENS, vol.4, pp.549-627, 2013. ,
Cylindrical algebraic decomposition, School of Math. Sciences, Univ. Bath, 1988. ,
Almost tight recursion tree bounds for the Descartes method, Proc. 31th ACM Int'l Symp. on Symbolic & Algebraic Comp. (ISSAC), pp.71-78, 2006. ,
Sparse Elimination and Applications in Kinematics, 1994. ,
The DMM bound: Multivariate (aggregate) separation bounds, Proc. 35th ACM Int'l Symp. on Symbolic & Algebraic Comp. (ISSAC), pp.243-250, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00393833
On the davenport-mahler bound, Journal of Complexity, vol.41, pp.72-81, 2017. ,
Discriminants, Resultants and Multidimensional Determinants, 1994. ,
La détermination des points isolés et de la dimension d'une variété algébrique peut se faire en temps polynomial, Proc. Int. Meeting on Commutative Algebra, 1993. ,
Multivariate Sturm-Habicht sequences: Real root counting on n-rectangles and triangles. Real Algebraic and Analytic Geometry (Segovia, 1995), Rev. Mat. Univ. Complut. Madrid, vol.10, pp.119-130, 1997. ,
On the minimum of a positive polynomial over the standard simplex, J. Symbolic Computation, vol.45, pp.434-442, 2010. ,
Algorithms for Polynomial Real Root Isolation, 1991. ,
Improved complexity bounds for computing with planar algebraic curves, J. Complexity, vol.31, 2015. ,
Sharp estimates for the arithmetic Nullstellensatz, Duke Math. J, vol.109, pp.521-598, 2001. ,
Continued fraction expansion of real roots of polynomial systems, Proc. Symbolic-Numeric Comput, pp.85-94, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00387399
Mathematics for Computer algebra, 1991. ,
On the distance between the roots of a polynomial, Appl. Algebra Eng. Commun. Comput, vol.6, pp.327-332, 1995. ,
Polynomials: An algorithmic approach, 1999. ,
On the solution of a set of polynomial equations, Symbolic & Numerical Computation for AI, pp.89-102, 1992. ,
Counting real zeros, 1991. ,
Counting real zeros in the multivariate case, Computational Algebraic Geometry. Birkhäuser, vol.109, pp.203-224, 1993. ,
Polynomial minimum root separation, Math. of Computation, vol.33, pp.327-336, 1979. ,
The height of the mixed sparse resultant, Amer. J. Math, vol.126, pp.1253-1260, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00119390
On the complexity of real root isolation using continued fractions, Theor. Comput. Sci, vol.392, pp.158-173, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00116990
Numerical analysis of a bisection-exclusion method to find zeros of univariate analytic functions, J. Complexity, vol.21, pp.652-690, 2005. ,
Fundamental Problems of Algorithmic Algebra, 2000. ,
