An exact algorithm and a metaheuristic for the generalized vehicle routing problem with flexible fleet size - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Operations Research Année : 2014
The generalized vehicle routing problem (GVRP )involves finding a minimum-length set of vehicle routes passing through a set of clusters,where each cluster contains a number of vertices,such that the tour includes exactly one vertex from each cluster and satisfies capacity constraints. We consider a version of the GVRP where the number of vehicles is a decision variable. This paper introduces a new mathematical formulation based on a two-commodity flow model.We solve the problem using a branch-and-cut algorithm and a metaheuristic that is a hybrid of the greedy randomized adaptive search procedure (GRASP) and the evolutionary local search (ELS) proposed in [18]. We perform computational experiments on instances from the literature to demonstrate the performance of our algorithms.
Fichier non déposé
hal-01105383 , version 1 (20-01-2015)
Minh Hoang Ha, Nathalie Bostel, André Langevin, Rousseau Louis-Martin. An exact algorithm and a metaheuristic for the generalized vehicle routing problem with flexible fleet size. Computers and Operations Research, 2014, 43, pp.9-19. ⟨10.1016/j.cor.2013.08.017⟩. ⟨hal-01105383⟩
67 Consultations
0 Téléchargements
