Journal articles
Errata: Fitting the optical constants of gold, silver, chromium, titanium and aluminum in the visible bandwidth
Abstract : This paper [J. Nanophoton. 8(1), 083097 (2014)] was published on 6 January 2014. Thanks to a question by Yoann Brûlé from the Fresnel institute (Marseille, France), we found that the values of γL and γD were swapped in tables in Ref. 1. The problem comes from a bug in the automatic extraction of data from optimization method. Fortunately the curves in Ref. 1 are correct. This erratum gives a more readily available formulation of fitting for all considered metals and the corresponding criteria.
Complete list of metadata
https://hal.inria.fr/hal-01107387
Contributor : Thomas Grosges Connect in order to contact the contributor
Submitted on : Tuesday, January 20, 2015 - 4:02:47 PM
Last modification on : Sunday, June 26, 2022 - 4:49:55 AM
Links full text
Identifiers
Collections
Citation
Dominique Barchiesi, Thomas Grosges. Errata: Fitting the optical constants of gold, silver, chromium, titanium and aluminum in the visible bandwidth. Journal of Nanophotonics, Society of Photo-optical Instrumentation Engineers, 2014, 8 (1), pp.4. ⟨10.1117/1.JNP.8.089996⟩. ⟨hal-01107387⟩
Share
Metrics
Record views
129
