Certifying isolated singular points and their multiplicity structure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents two new constructions related to singular solutions of polynomial systems. The first is a new deflation method for an isolated singular root. This construc-tion uses a single linear differential form defined from the Jacobian matrix of the input, and defines the deflated system by applying this differential form to the original system. The advantages of this new deflation is that it does not introduce new variables and the increase in the number of equations is linear instead of the quadratic increase of previous methods. The second construction gives the coefficients of the so-called inverse system or dual basis, which defines the multiplicity structure at the singular root. We present a system of equations in the original variables plus a relatively small number of new vari-ables. We show that the roots of this new system include the original singular root but now with multiplicity one, and the new variables uniquely determine the multiplicity structure. Both constructions are "exact", meaning that they permit one to treat all conjugate roots simultaneously and can be used in certification procedures for singular roots and their multiplicity structure with respect to an exact rational polynomial system.
paper-hal.pdf (247.59 Ko) Télécharger le fichier
hal-01107541 , version 1 (21-01-2015)
hal-01107541 , version 2 (14-09-2015)
Paternité - Pas d'utilisation commerciale - Pas de modification
Jonathan D. Hauenstein, Bernard Mourrain, Agnes Szanto. Certifying isolated singular points and their multiplicity structure. ISSAC'15, Jul 2015, Bath, United Kingdom. pp.213-220, ⟨10.1145/2755996.2756645⟩. ⟨hal-01107541v1⟩
967 Consultations
442 Téléchargements
