Physiologically informed Bayesian analysis of ASL fMRI data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Arterial Spin Labelling (ASL) functional Magnetic Resonance Imaging (fMRI) data provides a quantitative measure of blood perfusion, that can be correlated to neuronal activation. In contrast to BOLD measure, it is a direct measure of cerebral blood flow. However, ASL data has a lower SNR and resolution so that the recovery of the perfusion response of interest suffers from the contamination by a stronger hemodynamic component in the ASL signal. In this work we consider a model of both hemodynamic and perfusion components within the ASL signal. A physiological link between these two components is analyzed and used for a more accurate estimation of the perfusion response function in particular in the usual ASL low SNR conditions.
Fichier non déposé
hal-01107613 , version 1 (21-01-2015)
  • HAL Id : hal-01107613 , version 1
Florence Forbes, Aina Frau-Pascual, Thomas Vincent, Jennifer Sloboda, Philippe Ciuciu. Physiologically informed Bayesian analysis of ASL fMRI data. Statistical Challenges in Neuroscience workshop, Sep 2014, Warwick, United Kingdom. ⟨hal-01107613⟩
375 Consultations
0 Téléchargements
