Journal articles
Concurrent Aerodynamic Optimization of Rotor Blades Using a Nash Game Method
Abstract : A multi-objective strategy adapted to the aerodynamic concurrent optimization of helicopter rotor blades is developed. The present strategy is based on Nash Games from game theory, where the objective functions are minimized by vir- tual players involved in a non-cooperative concurrent game. A method is presented to split the design vector into two sub-spaces, defined to be the strategies of the players in charge of the minimization of the primary and the secondary objective functions respectively. This split of territory allows the optimization of the secondary function while causing the least possible degradation of the first one. This methodology is applied to the model rotor ERATO, seeking to max- imize the Figure of Merit in hover while minimizing the required rotor power in forward flight. An initial constrained optimization in hover is conducted using a previously developed adjoint-based technique using the 3D Navier-Stokes solver elsA along with the gradient-based CONMIN algorithm. The chord, twist and sweep distributions of the base- line blade are parametrized using Be ́zier and cubic splines for a total of 16 design variables. The obtained optimized rotor is then used as a starting point to launch constrained and unconstrained Nash games. The comprehensive rotor code HOST is used to evaluate forward flight performance and a surrogate model is built to obtain the hover perfor- mance at low computational cost. Twist and sweep distribution laws are optimized independently at first and then a final joint optimization involving twist, sweep and chord is performed. The results demonstrate the potential of this technique to obtain helicopter rotor designs realizing interesting trade-offs between strongly antagonistic objectives.
Complete list of metadata
https://hal.inria.fr/hal-01107662
Contributor : Jean-Antoine Désidéri <>
Submitted on : Wednesday, January 21, 2015 - 11:59:35 AM
Last modification on : Tuesday, March 16, 2021 - 3:44:45 PM
Identifiers
  • HAL Id : hal-01107662, version 1
Collections
Citation
Enric Roca Leon, Arnaud Le Pape, Jean-Antoine Desideri, David Alfano, Michel Costes. Concurrent Aerodynamic Optimization of Rotor Blades Using a Nash Game Method. Journal- American Helicopter Society, American Helicopter Society Inc, 2014, pp.12. ⟨hal-01107662⟩
Share
Metrics
Record views
459
