Multi-objective path relinking for bi-clustering: Application to microarray data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we deal with a multiobjective biclustering problem applied to microarray data. MOBI nsga [21] is one of the multiobjective metaheuristics that have been proposed to solve a new multiobjective formulation of the biclustering problem. Using MOBI nsga , biclusters of good quality can be extracted. However, the generated front approximation contains a lot of gaps. Using path relinking strategies, our aim is to improve the generated front’s quality by filling the gaps with new solutions. Therefore, we propose a general scheme PR-MOBI nsga of different possible hybridization of MOBI nsga with path relinking strategies. A comparison of different PR-MOBI nsga hybridizations is performed. Experimental results on reel data sets show that PR-MOBI nsga allows to extract new interesting solutions and to improve the Pareto front approximation generated by MOBI nsga .
hal-01107757 , version 1 (21-01-2015)
Khedidja Seridi, Laetitia Jourdan, El-Ghazali Talbi. Multi-objective path relinking for bi-clustering: Application to microarray data. EMO 2013 : 7th Int. Conf. On Evolutionary Multi-criterion Optimization, Mar 2014, Sheffield, United Kingdom. pp.200-214, ⟨10.1007/978-3-642-37140-0_18⟩. ⟨hal-01107757⟩
65 Consultations
0 Téléchargements
