New interface
Conference papers
Fast DNN training based on auxiliary function technique
Dung T. Tran 1 Nobutaka Ono 2 Emmanuel Vincent 3
1 PAROLE - Analysis, perception and recognition of speech
Inria Nancy - Grand Est, LORIA - NLPKD - Department of Natural Language Processing & Knowledge Discovery
3 MULTISPEECH - Speech Modeling for Facilitating Oral-Based Communication
Abstract : Deep neural networks (DNN) are typically optimized with stochastic gradient descent (SGD) using a fixed learning rate or an adaptive learning rate approach (ADAGRAD). In this paper, we introduce a new learning rule for neural networks that is based on an auxiliary function technique without parameter tuning. Instead of minimizing the objective function, a quadratic auxiliary function is recursively introduced layer by layer which has a closed-form optimum. We prove the monotonic decrease of the new learning rule. Our experiments show that the proposed algorithm converges faster and to a better local minimum than SGD. In addition, we propose a combination of the proposed learning rule and ADAGRAD which further accelerates convergence. Experimental evaluation on the MNIST database shows the benefit of the proposed approach in terms of digit recognition accuracy.
Document type :
Conference papers
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-01107809
Contributor : Dung Tran Connect in order to contact the contributor
Submitted on : Wednesday, February 11, 2015 - 3:26:40 PM
Last modification on : Monday, July 25, 2022 - 3:44:14 AM
Long-term archiving on: : Saturday, September 12, 2015 - 11:00:25 AM
File
Dung2015ICASSP_v6_final.pdf
Identifiers
  • HAL Id : hal-01107809, version 4
Citation
Dung T. Tran, Nobutaka Ono, Emmanuel Vincent. Fast DNN training based on auxiliary function technique. ICASSP 2015 - 40th IEEE International Conference on Acoustics, Speech and Signal Processing, Apr 2015, Brisbane, Queensland, Australia. ⟨hal-01107809v4⟩
Share
Metrics
Record views
318
Files downloads
634
