The Multi-Point Separation Strategy as a Column Generation Stabilization Technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Column generation suffers from slow convergence. Algorithmic strategies have been designed to accelerate convergence of cutting plane algorithms in mixed integer programming. They have their counterpart in column generation. We show that the "Multi-Point Separation" strategy translates into a column generation stabilization technique that consists in restricting the dual solution to be in the convex hull of the selected multi-point set.
Fichier non déposé
hal-01108143 , version 1 (22-01-2015)
  • HAL Id : hal-01108143 , version 1
François Vanderbeck, Artur Alves Pessoa, Ruslan Sadykov, Eduardo Uchoa. The Multi-Point Separation Strategy as a Column Generation Stabilization Technique. INFORMS Annual Meeting 2014, Nov 2014, San Francisco, United States. ⟨hal-01108143⟩
527 Consultations
0 Téléchargements
