Multidigit multiplication for mathematicians, 2001. ,
A heuristic asymptotic formula concerning the distribution of prime numbers, Math. Comput, vol.16, issue.79, p.363367, 1962. ,
A linear ltering approach to the computation of discrete Fourier transform, Audio and Electroacoustics, IEEE Transactions on, vol.18, issue.4, pp.451-455, 1970. ,
Modern computer arithmetic, 2010. ,
An algorithm for the machine calculation of complex Fourier series, Math. Comput, vol.19, pp.297301-017858631, 1965. ,
Distribution of generalized Fermat prime numbers, Mathematics of Computation, vol.71, issue.238, pp.825832-1885631, 2002. ,
DOI : 10.1090/S0025-5718-01-01350-3
Fast integer multiplication using modular arithmetic, 40th annual ACM symposium on Theory of computing STOC '08, p.499506, 2008. ,
DOI : 10.1145/1374376.1374447
URL : http://arxiv.org/abs/0801.1416
On the complexity of integer multiplication (extended abstract), Tech. Report CS-89-17 Faster integer multiplication, SIAM J. Comput, vol.39, issue.3, p.9791005, 1989. ,
A GMP-based implementation of Schönhage-Strassen's large integer multiplication algorithm, Proceedings of the 2007 International Symposium on Symbolic and Algebraic Computation ISSAC '07, p.167174, 2007. ,
The GNU Multiple Precision Arithmetic Library, 2016. ,
Faster polynomial multiplication via multipoint Kronecker substitution, Journal of Symbolic Computation, vol.44, issue.10, 2009. ,
DOI : 10.1016/j.jsc.2009.05.004
URL : http://doi.org/10.1016/j.jsc.2009.05.004
Faster integer multiplication using plain vanilla FFT primes, 2016. ,
Joris van der Hoeven, and Grégoire Lecerf, Even faster integer multiplication, J. Complexity, vol.36, p.130, 2016. ,
DOI : 10.1016/j.jco.2016.03.001
URL : http://arxiv.org/abs/1407.3360
Multiplication of multidigit numbers on automata, Soviet Physics-Doklady, vol.7, p.595596, 1963. ,
Computational complexity, 1994. ,
Schnelle multiplikation groÿer zahlen, Computing, vol.7, issue.3-4German, p.281292, 1971. ,
The complexity of a scheme of functional elements realizing the multiplication of integers, Soviet Mathematics Doklady, vol.3, p.714716, 1963. ,
Modern computer algebra, 1999. ,
