Fast integer multiplication using generalized Fermat primes - Archive ouverte HAL Access content directly
Journal Articles Mathematics of Computation Year : 2019
(1) , (1)
1
For almost 35 years, Schönhage-Strassen's algorithm has been the fastest algorithm known for multiplying integers, with a time complexity O(n · log n · log log n) for multiplying n-bit inputs. In 2007, Fürer proved that there exists K > 1 and an algorithm performing this operation in O(n · log n · K log n). Recent work by Harvey, van der Hoeven, and Lecerf showed that this complexity estimate can be improved in order to get K = 8, and conjecturally K = 4. Using an alternative algorithm, which relies on arithmetic modulo generalized Fermat primes, we obtain conjecturally the same result K = 4 via a careful complexity analysis in the deterministic multitape Turing model.
furer.pdf (425.93 Ko) Télécharger le fichier
Dates and versions
hal-01108166 , version 1 (22-01-2015)
hal-01108166 , version 2 (28-01-2016)
hal-01108166 , version 3 (10-08-2017)
hal-01108166 , version 4 (13-04-2018)
Identifiers
Cite
Svyatoslav Covanov, Emmanuel Thomé. Fast integer multiplication using generalized Fermat primes. Mathematics of Computation, 2019, 88 (317), pp.1449-1477. ⟨10.1090/mcom/3367⟩. ⟨hal-01108166v4⟩
1035 View
1257 Download
Share
