000 from the uniform distribution over the square (?2, 2) 2 . The function choice.grid was applied to these samples with N=30 and ng=1. The resulting couple of initial and optimal grids are plotted in Figure 7. As in the univariate case, we observe an improvement when going from the initial grids to the corresponding optimal grids provided by the function choice.grid (here as well, the population optimal grid should be uniformly spread over the support of the underlying distribution) ,
set.seed(345689) n <-2222 X <-matrix(runif(n*2, -2, 2), nc = n) N <-33 ng <-1 res <-choice.grid(X, N, ng) col <-c("red, res$init_grid, p.col ,
rgl: 3D visualization device system (OpenGL), 2014. URL http ,
Kernel and Nearest-Neighbor Estimation of a Conditional Quantile, The Annals of Statistics, vol.18, issue.3, pp.1400-1415, 1990. ,
DOI : 10.1214/aos/1176347757
Conditional quantile estimation through optimal quantization, Journal of Statistical Planning and Inference, vol.156, pp.14-30, 2015. ,
DOI : 10.1016/j.jspi.2014.08.003
URL : https://hal.archives-ouvertes.fr/hal-01108482
Conditional quantile estimation based on optimal quantization: From theory to practice, Computational Statistics & Data Analysis, vol.91, pp.20-39, 2015. ,
DOI : 10.1016/j.csda.2015.05.008
URL : https://hal.archives-ouvertes.fr/hal-01108504
QuantifQuantile: Estimation of conditional quantiles using optimal quantization, 2015c. URL http ,
Robust nonparametric function estimation, Scandinavian Journal of Statistics, vol.21, issue.4, pp.433-446, 1994. ,
Reference curves based on non-parametric quantile regression, Statistics in Medicine, vol.VIII, issue.20, pp.3119-3135, 2002. ,
DOI : 10.1002/sim.1226
Foundations of quantization for probability distributions, Lecture Notes in Mathematics, vol.1730, 2000. ,
DOI : 10.1007/BFb0103945
quantreg: Quantile Regression, 2013. ,
Regression Quantiles, Econometrica, vol.46, issue.1, pp.33-50, 1978. ,
DOI : 10.2307/1913643
Penalized triograms: total variation regularization for bivariate smoothing, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.5, issue.1, pp.145-163, 2004. ,
DOI : 10.1175/1520-0493(1980)108<1122:SNMMFV>2.0.CO;2
Quantile smoothing splines, Biometrika, vol.81, issue.4, pp.673-680, 1994. ,
DOI : 10.1093/biomet/81.4.673
quantregGrowth: Growth charts via regression quantiles, 2014. ,
Estimating growth charts via nonparametric quantile regression: a practical framework with application in ecology, Environmental and Ecological Statistics, vol.50, issue.4, pp.519-531, 2013. ,
DOI : 10.1007/s10651-012-0232-1
A space quantization method for numerical integration, Journal of Computational and Applied Mathematics, vol.89, issue.1, pp.1-38, 1998. ,
DOI : 10.1016/S0377-0427(97)00190-8
Optimal Quantization Methods and Applications to Numerical Problems in Finance, Handbook of computational and numerical methods in finance, pp.253-297, 2004. ,
DOI : 10.1007/978-0-8176-8180-7_7
Local Linear Quantile Regression, Journal of the American Statistical Association, vol.25, issue.441, pp.228-237, 1998. ,
DOI : 10.1080/01621459.1998.10474104
Quantile regression: applications and current research areas, Journal of the Royal Statistical Society: Series D (The Statistician), vol.93, issue.3, pp.331-350, 2003. ,
DOI : 10.1016/S0167-7152(01)00124-9
