A Pseudo-Markov Property for Controlled Diffusion Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2016
In this note, we propose two different approaches to rigorously justify a pseudo-Markov property for controlled diffusion processes which is often (explicitly or implicitly) used to prove the dynamic programming principle in the stochastic control literature. The first approach develops a sketch of proof proposed by Fleming and Souganidis [9]. The second approach is based on an enlargement of the original state space and a controlled martingale problem. We clarify some measurability and topological issues raised by these two approaches.
1501.03939v1.pdf (234.08 Ko) Télécharger le fichier
hal-01429545 , version 1 (08-01-2017)
Julien Claisse, Denis Talay, Xiaolu Tan. A Pseudo-Markov Property for Controlled Diffusion Processes. SIAM Journal on Control and Optimization, 2016, 54 (2), pp.1017 - 1029. ⟨10.1137/151004252⟩. ⟨hal-01429545⟩
630 Consultations
174 Téléchargements
