Journal articles
Bayesian inference for inverse problems occurring in uncertainty analysis
Abstract : The inverse problem considered here is the estimation of the distribution of a nonobserved random variable X, linked through a time-consuming physical model H to some noisy observed data Y. Bayesian inference is considered to account for prior expert knowledge on X in a small sample size setting. A Metropolis-Hastings-within-Gibbs algorithm is used to compute the posterior distribution of the parameters of the distribution of X through a data augmentation process. Since running H is quite expensive, this inference is achieved by a kriging emulator interpolating H from a numerical design of experiments (DOE). This approach involves several errors of different natures and, in this article, we pay effort to measure and reduce the possible impact of those errors. In particular, we propose to use the so-called DAC criterion to assess in the same exercise the relevance of the DOE and the prior distribution. After describing the calculation of this criterion for the emulator at hand, its behavior is illustrated on numerical experiments.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01108811
Contributor : Gilles Celeux Connect in order to contact the contributor
Submitted on : Friday, January 23, 2015 - 3:06:09 PM
Last modification on : Sunday, June 26, 2022 - 12:02:48 PM
Links full text
Identifiers
Collections
Citation
Shuai Fu, Gilles Celeux, Nicolas Bousquet, Mathieu Couplet. Bayesian inference for inverse problems occurring in uncertainty analysis. International Journal for Uncertainty Quantification, Begell House Publishers, 2014, 5 (1), pp.73-98. ⟨10.1615/Int.J.UncertaintyQuantification.2014011073⟩. ⟨hal-01108811⟩
Share
Metrics
Record views
107
