Conference papers
Construction of Quasi-Cyclic Product Codes
Abstract : Linear quasi-cyclic product codes over finite fields are investigated. Given the generating set in the form of a reduced Gröbner basis of a quasi-cyclic component code and the generator polynomial of a second cyclic component code, an explicit expression of the basis of the generating set of the quasi-cyclic product code is given. Furthermore, the reduced Gröbner basis of a one-level quasi-cyclic product code is derived.
Complete list of metadata
https://hal.inria.fr/hal-01109353
Contributor : Alexander Zeh <>
Submitted on : Monday, January 26, 2015 - 7:36:29 PM
Last modification on : Sunday, December 31, 2017 - 9:44:02 AM
Long-term archiving on: : Monday, April 27, 2015 - 10:17:01 AM
QCCProduct_ZehLing.pdf
Identifiers
  • HAL Id : hal-01109353, version 1
Citation
Alexander Zeh, San Ling. Construction of Quasi-Cyclic Product Codes. 10th International ITG Conference on Systems, Communications and Coding (SCC), Feb 2015, Hamburg, Germany. ⟨hal-01109353v1⟩
Share
Metrics
Record views
13
Files downloads
17
