R. Aboula¨?chaboula¨?ch, A. B. Abda, and M. Kallel, Missing boundary data reconstruction via an approximate optimal control, Inverse Problems and Imaging, vol.2, issue.4, pp.411-426, 2008.
DOI : 10.3934/ipi.2008.2.411
S. Andrieux, T. N. Baranger, and A. B. Abda, Solving Cauchy problems by minimizing an energy-like functional, Inverse Problems, vol.22, issue.1, pp.115-133, 2006.
DOI : 10.1088/0266-5611/22/1/007
URL : https://hal.archives-ouvertes.fr/hal-00139569
A. B. Abda, R. B. Fatma, and D. Tromeur-dervout, An Aitken-like acceleration method applied to missing boundary data reconstruction for the Cauchy???Helmholtz problem, Comptes Rendus Mathematique, vol.348, issue.1-2, pp.93-97, 2010.
DOI : 10.1016/j.crma.2009.11.010
URL : https://hal.archives-ouvertes.fr/hal-00951456
F. and B. Belgacem, Why is the Cauchy problem severely ill-posed? Inverse Problems, pp.823-836, 2007.
F. B. Belgacem, D. Du, and F. Jelassi, Extended-domain-Lavrentiev's regularization for the Cauchy problem, Inverse Problems, vol.27, issue.4, p.45005, 2011.
DOI : 10.1088/0266-5611/27/4/045005
F. , B. Belgacem, and H. Fekih, On Cauchy's problem. I. A variational Steklov-Poincaré theory, Inverse Problems, vol.21, issue.6, pp.1915-1936, 2005.
L. Bourgeois, Convergence rates for the quasi-reversibility method to solve the Cauchy problem for Laplace's equation, Inverse Problems, vol.22, issue.2, pp.413-430, 2006.
DOI : 10.1088/0266-5611/22/2/002
L. Bourgeois, domains, ESAIM: Mathematical Modelling and Numerical Analysis, vol.44, issue.4, pp.715-735, 2010.
DOI : 10.1051/m2an/2010016
URL : https://hal.archives-ouvertes.fr/hal-00849579
L. Bourgeois and J. Dardé, A duality-based method of quasi-reversibility to solve the Cauchy problem in the presence of noisy data, Inverse Problems, vol.26, issue.9, p.95016, 2010.
DOI : 10.1088/0266-5611/26/9/095016
URL : https://hal.archives-ouvertes.fr/hal-00873058
F. Cakoni and R. Kress, Integral equations for inverse problems in corrosion detection from partial Cauchy data, Inverse Probl. Imaging, vol.1, issue.2, pp.229-245, 2007.
H. Cao, M. V. Klibanov, and S. V. Pereverzev, A Carleman estimate and the balancing principle in the quasi-reversibility method for solving the Cauchy problem for the Laplace equation, Inverse Problems, vol.25, issue.3, p.35005, 2009.
DOI : 10.1088/0266-5611/25/3/035005
A. Cimetì-ere, F. Delvare, M. Jaoua, and F. Pons, Solution of the Cauchy problem using iterated Tikhonov regularization, Inverse Problems, vol.17, issue.3, pp.553-570, 2001.
DOI : 10.1088/0266-5611/17/3/313
D. Colton and R. Kress, Inverse acoustic and eletromagnetic scattering theory, 1998.
DOI : 10.1007/978-1-4614-4942-3
J. Dardé, A. Hannukainen, and N. Hyvönen, An $H_\mathsf{div}$-Based Mixed Quasi-reversibility Method for Solving Elliptic Cauchy Problems, SIAM Journal on Numerical Analysis, vol.51, issue.4, pp.2123-2148, 2013.
DOI : 10.1137/120895123
A. Habbal and M. Kallel, Neumann--Dirichlet Nash Strategies for the Solution of Elliptic Cauchy Problems, SIAM Journal on Control and Optimization, vol.51, issue.5, pp.4066-4083, 2013.
DOI : 10.1137/120869808
URL : https://hal.archives-ouvertes.fr/hal-00923574
H. Han and H. Reinhardt, Some stability estimates for Cauchy problems for elliptic equations, Journal of Inverse and Ill-Posed Problems, vol.5, issue.5, pp.437-454, 1997.
DOI : 10.1515/jiip.1997.5.5.437
D. Nho, H. , and D. Lesnic, The Cauchy Problem for Laplace´sLaplace´s equation using the Conjugate Gradient Method, IMA J. Appl. Math, pp.199-217, 2000.
D. Nho, H. Phan-xuan-thanh, D. Lesnic, and B. T. Johansson, A boundary element a method for a multi-dimensional inverse heat conduction problem, Inter. J. Comput. Math, pp.1540-21554, 2012.
V. Isakov and S. Kindermann, Subspaces of stability in the Cauchy Problem for the Helmholtz equation, Methods and Applications of Analysis, vol.18, issue.1, pp.1-29, 2011.
DOI : 10.4310/MAA.2011.v18.n1.a1
L. J. Belaid, A. B. Abda, and N. Malki, The Cauchy problem for the Laplace equation and application to image inpainting, ISRN Math. Anal, vol.11, 2011.
M. V. Klibanov and F. Santosa, A Computational Quasi-Reversibility Method for Cauchy Problems for Laplace???s Equation, SIAM Journal on Applied Mathematics, vol.51, issue.6, pp.1653-1675, 1991.
DOI : 10.1137/0151085
V. A. Kozlov, V. G. Maz, and A. V. Fomin, An iterative method for solving the Cauchy problem for elliptic equations, Zh. Vychisl. Mat. i Mat. Fiz, vol.31, issue.1, pp.64-74, 1991.
R. Lattès and J. Lions, Méthode de quasi-réversibilité et applications, Travaux et Recherches Mathématiques, issue.15, 1967.
L. Marin, L. Elliott, P. J. Heggs, D. B. Ingham, D. Lesnic et al., Comparison of regularization methods for solving the Cauchy problem associated with the Helmholtz equation, International Journal for Numerical Methods in Engineering, vol.60, issue.11, pp.601933-1947, 2004.
DOI : 10.1002/nme.1031
W. Mclean, Strongly elliptic systems and boundary integral equations, 2000.
H. Reinhardt, H. Han, D. Nho, and H. , Stability and Regularization of a Discrete Approximation to the Cauchy Problem for Laplace's Equation, SIAM Journal on Numerical Analysis, vol.36, issue.3, pp.890-905, 1999.
DOI : 10.1137/S0036142997316955
