Journal articles
Greedy Geometric Algorithms for Collection of Balls, with Applications to Geometric Approximation and Molecular Coarse-Graining
Abstract : Choosing balls which best approximate a 3D object is a non trivial problem. To answer it, we first address the inner approximation problem, which consists of approximating an object FO defined by a union of n balls with k < n balls defining a region FS ⊂ FO. This solution is further used to construct an outer approximation enclosing the initial shape, and an interpolated approximation sandwiched between the inner and outer approximations. The inner approximation problem is reduced to a geometric generalization of weighted max k-cover, solved with the greedy strategy which achieves the classical 1 − 1/e lower bound. The outer approximation is reduced to exploiting the partition of the boundary of FO by the Apollonius Voronoi diagram of the balls defining the inner approximation. Implementation-wise, we present robust software incorporating the calculation of the exact Delau-nay triangulation of points with degree two algebraic coordinates, of the exact medial axis of a union of balls, and of a certified estimate of the volume of a union of balls. Application-wise, we exhibit accurate coarse-grain molecular models using a number of balls 20 times smaller than the number of atoms, a key requirement to simulate crowded cellular environments.
Document type :
Journal articles
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-01110229
Contributor : Frederic Cazals Connect in order to contact the contributor
Submitted on : Tuesday, January 27, 2015 - 4:57:19 PM
Last modification on : Saturday, June 25, 2022 - 11:15:38 PM
Long-term archiving on: : Tuesday, April 28, 2015 - 11:11:31 AM
File
greedy-balls-final.pdf
Identifiers
Collections
Citation
Frédéric Cazals, Tom Dreyfus, S Sachdeva, N Shah. Greedy Geometric Algorithms for Collection of Balls, with Applications to Geometric Approximation and Molecular Coarse-Graining. Computer Graphics Forum, Wiley, 2014, 33, pp.1 - 17. ⟨10.1111/cgf.12270⟩. ⟨hal-01110229⟩
Share
Metrics
Record views
77
Files downloads
297
