New interface
Journal articles
Identifying defects in an unknown background using differential measurements
Abstract : We present a new qualitative imaging method capable of selecting defects in complex and unknown background from differential measurements of farfield operators: i.e. far measurements of scattered waves in the cases with and without defects. Indeed, the main difficulty is that the background physical properties are unknown. Our approach is based on a new exact characterization of a scatterer domain in terms of the far field operator range and the link with solutions to so-called interior transmission problems. We present the theoretical foundations of the method and some validating numerical experiments in a two dimensional setting.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01110270
Contributor : Houssem Haddar Connect in order to contact the contributor
Submitted on : Tuesday, January 27, 2015 - 5:52:47 PM
Last modification on : Wednesday, August 24, 2022 - 9:40:06 AM
Links full text
Identifiers
Citation
Lorenzo Audibert, Girard Alexandre, Houssem Haddar. Identifying defects in an unknown background using differential measurements. Inverse Problems and Imaging , 2015, 9 (3), ⟨10.3934/ipi.2015.9.625⟩. ⟨hal-01110270⟩
Share
Metrics
Record views
221
