New interface
Journal articles
Homogenization of the transmission eigenvalue problem for periodic media and application to the inverse problem
Fioralba Cakoni 1 Houssem Haddar 2 Isaac Harris 1
2 DeFI - Shape reconstruction and identification
CMAP - Centre de Mathématiques Appliquées - Ecole Polytechnique, Inria Saclay - Ile de France
Abstract : We consider the interior transmission problem associated with the scattering by an inhomogeneous (possibly anisotropic) highly oscillating periodic media. We show that, under appropriate assumptions, the solution of the interior transmission problem converges to the solution of a homogenized problem as the period goes to zero. Furthermore, we prove that the associated real transmission eigenvalues converge to transmission eigenvalues of the homogenized problem. Finally we show how to use the first transmission eigenvalue of the period media, which is measurable from the scattering data, to obtain information about constant effective material properties of the periodic media. The convergence results presented here are not optimal. Such results with rate of convergence involve the analysis of the boundary correction and will be subject of a forthcoming paper.
Document type :
Journal articles
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-01110294
Contributor : Houssem Haddar Connect in order to contact the contributor
Submitted on : Tuesday, January 27, 2015 - 6:43:15 PM
Last modification on : Friday, November 18, 2022 - 9:28:25 AM
Long-term archiving on: : Saturday, September 12, 2015 - 6:37:03 AM
File
IPI-CHH.pdf
Identifiers
Citation
Fioralba Cakoni, Houssem Haddar, Isaac Harris. Homogenization of the transmission eigenvalue problem for periodic media and application to the inverse problem. Inverse Problems and Imaging , 2015, 9 (4), pp.1025 - 1049. ⟨10.3934/ipi.2015.9.1025⟩. ⟨hal-01110294⟩
Share
Metrics
Record views
371
Files downloads
266
