CMA-ES: A Function Value Free Second Order Optimization Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We give a bird's-eye view introduction to the Covariance Matrix Adaptation Evolution Strategy (CMA-ES) and emphasize relevant design aspects of the algorithm, namely its invariance properties. While CMA-ES is gradient and function value free, we show that using the gradient in CMA-ES is possible and can reduce the number of iterations on unimodal, smooth functions.
hansen-pgmo-copi-2014.pdf (451.5 Ko) Télécharger le fichier
hal-01110313 , version 1 (29-01-2015)
  • HAL Id : hal-01110313 , version 1
Nikolaus Hansen. CMA-ES: A Function Value Free Second Order Optimization Method. PGMO COPI 2014 - Gaspard Monge Program for Optimization and operations research Conference on Optimization and Practices in Industry, Oct 2014, Saclay, France. ⟨hal-01110313⟩
569 Consultations
548 Téléchargements
