Newton's method for linear complementarity problems, Mathematical Programming, pp.349-362, 1984. ,
DOI : 10.1007/BF02612339
A generalized saddle point result for constrained optimization, Mathematical Programming, pp.225-234, 1973. ,
Finding optimal algorithmic parameters using derivative-free optimization, SIAM Journal on Optimization, vol.17, pp.642-664, 2006. ,
Nonconvergence of the plain Newton-min algorithm for linear complementarity problems with a P-matrix, Mathematical Programming, pp.349-364, 2012. ,
DOI : 10.1007/s10107-010-0439-6
URL : https://hal.archives-ouvertes.fr/inria-00442293
An Algorithmic Characterization of $P$-Matricity, SIAM Journal on Matrix Analysis and Applications, vol.34, issue.3, pp.904-916, 2013. ,
DOI : 10.1137/120883025
URL : https://hal.archives-ouvertes.fr/hal-00713330
Practical Augmented Lagrangian Methods for Constrained Optimization, p.10, 2014. ,
DOI : 10.1137/1.9781611973365
Numerical Optimization ? Theoretical and Practical Aspects (second edition). Universitext, p.14, 2006. ,
Dual algorithms for constrained optimization, 1972. ,
A trust region method based on interior point techniques for nonlinear programming, Mathematical Programming, pp.149-185, 2000. ,
DOI : 10.1007/PL00011391
URL : https://hal.archives-ouvertes.fr/inria-00073794
How the augmented Lagrangian algorithm can deal with an infeasible convex quadratic optimization problem, Journal of Convex Analysis, vol.22, issue.9, p.11, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01057577
LANCELOT: A Fortran Package for Large- Scale Nonlinear Optimization (Release A), Computational Mathematics, vol.17, issue.6, 1992. ,
DOI : 10.1007/978-3-662-12211-2
A globally convergent primal-dual active-set framework for large-scale convex quadratic optimization, Computational Optimization and Applications, vol.80, issue.389, 2014. ,
DOI : 10.1007/s10589-014-9681-9
An augmented Lagrangian approach to the numerical solution of the Dirichlet problem for the elliptic Monge-Ampère equation in two dimensions, Electronic Transactions on Numerical Analysis, vol.22, issue.6, pp.71-96, 2006. ,
Global linear convergence of an augmented Lagrangian algorithm for solving convex quadratic optimization problems, Journal of Convex Analysis, vol.12, issue.6 9, pp.45-69, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00071556
Optimality Measures for Performance Profiles, SIAM Journal on Optimization, vol.16, issue.3, pp.891-909, 2006. ,
DOI : 10.1137/040608015
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.131.179
Augmented Lagrangians with Adaptive Precision Control for Quadratic Programming with Simple Bounds and Equality Constraints, SIAM Journal on Optimization, vol.13, issue.4, pp.37-53, 1999. ,
DOI : 10.1137/S1052623499362573
Augmented Lagrangians with Adaptive Precision Control for Quadratic Programming with Simple Bounds and Equality Constraints, SIAM Journal on Optimization, vol.13, issue.4, pp.1120-1140, 2003. ,
Augmented Lagrangians with adaptive precision control for quadratic programming with equality constraints: corrigendum and addendum, Computational Optimization and Applications, vol.23, issue.1, pp.127-133, 2000. ,
DOI : 10.1023/A:1019980809734
An algorithm for quadratic programming, Naval Research Logistics Quarterly, vol.3, issue.1-2, pp.95-110, 1956. ,
DOI : 10.1002/nav.3800030109
Global and Finite Termination of a Two-Phase Augmented Lagrangian Filter Method for General Quadratic Programs, SIAM Journal on Scientific Computing, vol.30, issue.4, pp.1706-1726, 2008. ,
DOI : 10.1137/060669930
Object-oriented software for quadratic programming, ACM Transactions on Mathematical Software, vol.29, issue.1, pp.58-81, 2003. ,
DOI : 10.1145/641876.641880
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.108.9532
Inside OQLA and QPALM, p.14, 2014. ,
Some numerical experiments with variable-storage quasi- Newton algorithms, Mathematical Programming, pp.407-435, 1989. ,
Practical Optimization, 1981. ,
GALAHAD, a library of thread-safe Fortran 90 packages for large-scale nonlinear optimization, ACM Transactions on Mathematical Software, vol.29, issue.4, 2003. ,
DOI : 10.1145/962437.962438
Cutest: a constrained and unconstrained testing environment with safe threads, 2013. ,
Augmented Lagrangian algorithms for linear programming, Journal of Optimization Theory and Applications, vol.9, issue.3, pp.445-470, 1992. ,
DOI : 10.1007/BF00940486
Projection methods for conic feasibility problems: applications to polynomial sum-of-squares decompositions. Optimization Methods and Software, pp.23-46, 2009. ,
Multiplier and gradient methods, Journal of Optimization Theory and Applications, vol.4, issue.5, pp.303-320, 1969. ,
DOI : 10.1007/BF00927673
Convex Analysis and Minimization Algorithms. Grundlehren der mathematischen Wissenschaften 305-306, p.13, 1993. ,
DOI : 10.1007/978-3-662-02796-7
Lagrange Multiplier Approach to Variational Problems and Applications, 2008. ,
DOI : 10.1137/1.9780898718614
Newton-Type Methods for Optimization and Variational Problems, Series in Operations Research and Financial Engineering, 2014. ,
DOI : 10.1007/978-3-319-04247-3
On the limited memory BFGS method for large scale optimization, Mathematical Programming, pp.503-520, 1989. ,
DOI : 10.1007/BF01589116
A Dual Approach to Semidefinite Least-Squares Problems, SIAM Journal on Matrix Analysis and Applications, vol.26, issue.1, pp.272-284, 2004. ,
DOI : 10.1137/S0895479802413856
URL : https://hal.archives-ouvertes.fr/inria-00072409
Regularization Methods for Semidefinite Programming, SIAM Journal on Optimization, vol.20, issue.1, pp.336-356, 2009. ,
DOI : 10.1137/070704575
URL : https://hal.archives-ouvertes.fr/hal-00389552
On the Solution of Large Quadratic Programming Problems with Bound Constraints, SIAM Journal on Optimization, vol.1, issue.1, pp.93-113, 1991. ,
DOI : 10.1137/0801008
Proximit?? et dualit?? dans un espace hilbertien, Bulletin de la Société mathématique de France, vol.79, issue.5, pp.273-299, 1965. ,
DOI : 10.24033/bsmf.1625
URL : http://archive.numdam.org/article/BSMF_1965__93__273_0.pdf
Numerical Optimization (second edition) Springer Series in Operations Research, p.14, 2006. ,
A certain iteration method of linear programming and its economic interpretationin russian, Èkonomika i Matematicheskie Metody, vol.8, pp.740-751, 1972. ,
A method for nonlinear constraints in minimization problems, Optimization, pp.283-298, 1969. ,
New applications of duality in convex programming, Proceedings of the 4th Conference of Probability, pp.73-81, 1971. ,
A dual approach to solving nonlinear programming problems by unconstrained optimization, Mathematical Programming, pp.354-373, 1973. ,
DOI : 10.1007/BF01580138
The multiplier method of Hestenes and Powell applied to convex programming, Journal of Optimization Theory and Applications, vol.8, issue.6, pp.555-562, 1973. ,
DOI : 10.1007/BF00934777
Augmented Lagrange Multiplier Functions and Duality in Nonconvex Programming, SIAM Journal on Control, vol.12, issue.2, pp.268-285, 1974. ,
DOI : 10.1137/0312021
Some Properties of the Augmented Lagrangian in Cone Constrained Optimization, Mathematics of Operations Research, vol.29, issue.3, pp.479-491, 2004. ,
DOI : 10.1287/moor.1040.0103
Semismooth Newton Methods for Variational Inequalities and Constrained Optimization Problems in Function Spaces, MPS-SIAM Series on Optimization, vol.11, issue.2, 2011. ,
DOI : 10.1137/1.9781611970692
Alternating direction augmented Lagrangian methods for semidefinite programming, Mathematical Programming Computation, vol.20, issue.3-4, pp.203-230, 2010. ,
DOI : 10.1007/s12532-010-0017-1
Primal-Dual Interior-Point Methods, 1997. ,
DOI : 10.1137/1.9781611971453
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.129.5633
