The first-passage time of the Brownian motion to a curved boundary: an algorithmic approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2016
Under some weak conditions, the first-passage time of the Brownian motion to a continuous curved boundary is an almost surely finite stopping time. Its probability density function (pdf) is explicitly known only in few particular cases. Several mathematical studies proposed to approximate the pdf in a quite general framework or even to simulate this hitting time using a discrete time approximation of the Brownian motion. The authors study a new algorithm which permits to simulate the first-passage time using an iterating procedure. The convergence rate presented in this paper suggests that the method is very efficient.
hal-01110387 , version 1 (28-01-2015)
Samuel Herrmann, Etienne Tanré. The first-passage time of the Brownian motion to a curved boundary: an algorithmic approach. SIAM Journal on Scientific Computing, 2016, 38 (1), pp.A196-A215. ⟨10.1137/151006172⟩. ⟨hal-01110387⟩
414 Consultations
3 Téléchargements
