Parity-Check Relations on Combination Generators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2012
A divide-and-conquer cryptanalysis can often be mounted against some keystream generators composed of several (possibly nonlinear) independent devices combined by a Boolean function. In particular, any parity-check relation derived from the periods of some constituent sequences usually leads to a distinguishing attack whose complexity is determined by the bias of the relation. However, estimating this bias is a difficult problem since the piling-up lemma cannot be used. Here, we give two exact expressions for this bias. Most notably, these expressions lead to a new algorithm for computing the bias of a parity-check relation, and they also provide some simple formulas for this bias in some particular cases which are commonly used in cryptography, namely resilient functions and plateaued functions. We also show how to build parity-check relations with the highest possible bias in some particularly relevant cases.
Fichier non déposé
hal-01110509 , version 1 (28-01-2015)
Anne Canteaut, María Naya-Plasencia. Parity-Check Relations on Combination Generators. IEEE Transactions on Information Theory, 2012, 58 (6), pp.3900-3911. ⟨10.1109/TIT.2012.2184736⟩. ⟨hal-01110509⟩
Collections
INRIA INRIA2
27 Consultations
0 Téléchargements
