New interface
Conference papers
Automations for verifying floating-point algorithms
Abstract : Floating-point numbers are limited both in range and in precision, yet they are widely used as a way to implement computations on real numbers. Thus arithmetic operations cause small errors that might be amplified during subsequent computations. As such, it is important to guarantee that the computed values are still close enough to the ideal results. The traditional way to tackle the verification of such programs is to perform an error analysis, possibly using automated tools. Unfortunately, when it comes to the low-level floating-point functions found in mathematical libraries, the code is usually so contrived that this approach falls short. Falling back to a pen-and-paper proof makes it possible to verify such functions, but this process is long, tedious, and error-prone. Formal proofs take care of that last point, but they come at an even greater cost for the user. Thus one needs to recover some automations inside proof assistants to ease the verification process. This talk will present an overview of some of the methods available for the Coq proof assistant. In particular, it will focus on Gappa and some other interval-based automations. The presentation will not really be about the inner workings of these methods, but rather show how they can be used in practice to verify some floating-point algorithms in Coq.
Complete list of metadata
https://hal.inria.fr/hal-01110666
Contributor : Guillaume Melquiond Connect in order to contact the contributor
Submitted on : Wednesday, January 28, 2015 - 4:14:18 PM
Last modification on : Tuesday, October 25, 2022 - 4:18:22 PM
Identifiers
  • HAL Id : hal-01110666, version 1
Citation
Guillaume Melquiond. Automations for verifying floating-point algorithms. 5th Coq Workshop, Jul 2013, Rennes, France. ⟨hal-01110666⟩
Share
Metrics
Record views
93
