Secure the Clones - Static Enforcement of Policies for Secure Object Copying - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Exchanging mutable data objects with untrusted code is a delicate matter because of the risk of creating a data space that is accessible by an attacker. Consequently, secure programming guidelines for Java stress the importance of using defensive copying before accepting or handing out references to an inter-nal mutable object. However, implementation of a copy method (like clone()) is entirely left to the programmer. It may not provide a sufficiently deep copy of an object and is subject to overriding by a malicious sub-class. Currently no language-based mechanism supports secure object cloning. This paper proposes a type-based annotation system for defining modular copy policies for class-based object-oriented programs. A copy policy specifies the maximally allowed sharing between an object and its clone. We present a static enforcement mechanism that will guarantee that all classes fulfill their copy policy, even in the presence of overriding of copy methods, and establish the semantic correctness of the over-all approach in Coq. The mechanism has been implemented and experimentally evaluated on clone methods from several Java libraries.
esop11.pdf (905.95 Ko) Télécharger le fichier
hal-01110817 , version 1 (28-01-2015)
  • HAL Id : hal-01110817 , version 1
Thomas Jensen, Florent Kirchner, David Pichardie. Secure the Clones - Static Enforcement of Policies for Secure Object Copying. ESOP 2011, 2011, Saarbrucken, Germany. ⟨hal-01110817⟩
230 Consultations
52 Téléchargements
