Model Differencing for Textual DSLs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
—The syntactic and semantic comparison of models is important for understanding and supporting their evolution. In this paper we present TMDIFF, a technique for semanti-cally comparing models that are represented as text. TMDIFF incorporates the referential structure of a language, which is determined by symbolic names and language-specific scoping rules. Furthermore, it employs a novel technique for matching entities existing in source and target versions of a model, and finds entities that are added or removed. As a result, TMDIFF is fully language parametric, and brings the benefits of model differencing to textual languages.
Autre [cs.OH]
storm.pdf (111.07 Ko) Télécharger le fichier
hal-01110856 , version 1 (29-01-2015)
  • HAL Id : hal-01110856 , version 1
Riemer van Rozen, Tijs van Der Storm. Model Differencing for Textual DSLs. BENEVOL 2014 - Proceedings of the Belgian-Netherlands Evoluation Workshop, 2014, Amsterdam, Netherlands. ⟨hal-01110856⟩
Collections
INRIA INRIA2
55 Consultations
67 Téléchargements
