Abstract : A series of list appends or monadic binds for many monads per-
forms algorithmically worse when left-associated. Continuation-
passing style (CPS) is well-known to cure this severe dependence
of performance on the association pattern. The advantage of CPS
dwindles or disappears if we have to examine or modify the inter-
mediate result of a series of appends or binds, before continuing
the series. Such examination is frequently needed, for example, to
control search in non-determinism monads.
We present an alternative approach that is just as general as CPS
but more robust: it makes series of binds and other such opera-
tions efficient regardless of the association pattern – and also pro-
vides efficient access to intermediate results. The key is to represent
such a conceptual sequence as an efficient sequence data structure.
Efficient sequence data structures from the literature are homoge-
neous and cannot be applied as they are in a type-safe way to series
of monadic binds. We generalize them to
type aligned sequences
and show how to construct their (assuredly order-preserving) im-
plementations. We demonstrate that our solution solves previously
undocumented, severe performance problems in iteratees, LogicT
transformers, free monads and extensible effects
