Abstract : Radial-based 3D watermarking alters the distances between the center of mass of the 3D mesh and its vertices. These watermarking systems are inherently sensitive to cropping. To address this limitation, this paper introduces a complementary blind resynchronization module to transmit critical synchronization information to the watermark decoder. Spherical patterns formed by several secret landmark vertices are embedded alongside the payload and blindly retrieved by the decoder, thereby conveying the synchronization information needed. Experimental results showcase significant improvement against cropping, while preserving performances against valumetric attacks thanks to a control parameter that automatically switches between alternate resynchronization modes.
Type de document :
Communication dans un congrès
IEEE International Conference on Acoustic, Speech Signal Processing (ICASSP), Apr 2015, Brisbane, Australia
https://hal.inria.fr/hal-01111196
Contributeur : Pierre Alliez
Soumis le : jeudi 29 janvier 2015 - 18:12:49
Dernière modification le : jeudi 11 janvier 2018 - 16:36:01
Rolland-Nevière Xavier, Gwenaël Doërr, Pierre Alliez. Anti-Cropping Blind Resynchronization for 3D Watermarking. IEEE International Conference on Acoustic, Speech Signal Processing (ICASSP), Apr 2015, Brisbane, Australia. 〈hal-01111196〉
