Abstract : Novelty Search (NS) is a unique approach towards search and optimization,
where an explicit objective function is replaced by a measure of solution novelty
to provide the selective pressure in an artificial evolutionary system. However,
NS has been mostly used in evolutionary robotics, while it’s applicability to classic
machine learning problems has been mostly unexplored. This work presents a NSbased
Genetic Programming (GP) algorithm for supervised classification, with the
following noteworthy contributions. It is shown that NS can solve real-world classification
tasks, validated over several commonly used benchmarks. These results are
made possible by using a domain-specific behavioral descriptor, closely related to the
concept of semantics in GP.Moreover, two new variants of the NS algorithm are proposed,
Probabilistic NS (PNS) and a variant ofMinimum Criterion NS (MCNS). The
former models the behavior of each solution as a random vector, eliminating all the
NS parameters and reducing the computational overhead of the traditional NS algorithm;
the latter uses a standard objective function to constrain the search and bias the
process towards high performance solutions. The paper also discusses the effects of
NS on an important GP phenomenon, bloat. In particular, results indicate that some
variants of the NS approach can have a beneficial effect on the search process by
curtailing code growth.
