3D Hardware Canaries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
3D integration is a promising advanced manufacturing process offering a variety of new hardware security protection opportunities. This paper presents a way of securing 3D ICs using Hamiltonian paths as hardware integrity verification sensors. As 3D integration consists in the stacking of many metal layers, one can consider surrounding a security-sensitive circuit part by a wire cage. After exploring and comparing different cage construction strategies (and reporting preliminary implementation results on silicon), we introduce a ”hardware canary”. The canary is a spatially distributed chain of functions F i positioned at the vertices of a 3D cage surrounding a protected circuit. A correct answer (F n  ∘ … ∘ F 1)(m) to a challenge m attests the canary’s integrity
hal-01111533 , version 1 (30-01-2015)
Sébastien Briais, Stéphane Caron, Jean-Michel Cioranesco, Jean-Luc Danger, Sylvain Guilley, et al.. 3D Hardware Canaries. CHES 2012 - 14th International Workshop Cryptographic Hardware and Embedded Systems, Sep 2012, Leuven, Belgium. pp.1-22, ⟨10.1007/978-3-642-33027-8_1⟩. ⟨hal-01111533⟩
193 Consultations
0 Téléchargements
