A Schwarz Waveform Relaxation Method for Advection—Diffusion—Reaction Problems with Discontinuous Coefficients and Non-matching Grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We present a non-overlapping Schwarz waveform relaxation method for solving advection-reaction-diffusion problems in heterogeneous media. The do-main decomposition method is global in time, which permits the use of different time steps in different subdomains. We determine optimal non-local, and optimized Robin transmission conditions. We also present a space-time finite volume scheme es-pecially designed to handle such transmission conditions. We show the performance of the method on an example inspired from nuclear waste disposal simulations.
kern_mini_5.pdf (213.7 Ko) Télécharger le fichier
hal-01111940 , version 1 (01-02-2015)
Martin J. Gander, Laurence Halpern, Michel Kern. A Schwarz Waveform Relaxation Method for Advection—Diffusion—Reaction Problems with Discontinuous Coefficients and Non-matching Grids. Domain Decomposition Methods in Science and Engineering 16, Jan 2005, New-York, United States. ⟨10.1007/978-3-540-34469-8_33⟩. ⟨hal-01111940⟩
281 Consultations
250 Téléchargements
