Polly Cracker, Revisited, Advances in Cryptology ? ASIACRYPT 2011, pp.179-196, 2011. ,
DOI : 10.1007/978-3-642-25385-0_10
URL : https://hal.archives-ouvertes.fr/hal-01112976
Polynomials With Errors (PWE). in preparation, 2012. ,
Fast Cryptographic Primitives and Circular-Secure Encryption Based on Hard Learning Problems, Advances in Cryptography -CRYPTO 2009, pp.595-618, 2009. ,
DOI : 10.1007/978-3-642-03356-8_35
New Algorithms for Learning in Presence of Errors, Lecture Notes in Computer Science, vol.6755, issue.1, pp.403-415, 2011. ,
DOI : 10.1007/978-3-540-85174-5_31
Applications des bases de GröbnerGröbner`Gröbnerà la cryptographie, 2005. ,
Efficient methods for conversion and solution of sparse systems of low-degree multivariate polynomials over GF(2) via SAT-solvers. Cryptology ePrint Archive, Report, vol.024, p.24, 2007. ,
´ Etude des systèmes algébriques surdéterminés Applications aux codes correcteurs etàet`età la cryptographie, 2004. ,
On the complexity of Gröbner basis computation of semi-regular overdetermined algebraic equations, International Conference on Polynomial System Solving - ICPSS, pp.71-75, 2004. ,
Asymptotic expansion of the degree of regularity for semi-regular systems of equations, Algebraic Geometry Conference, pp.1-14, 2005. ,
Why You Cannot Even Hope to use Gr??bner Bases in Public Key Cryptography: An Open Letter to a Scientist Who Failed and a Challenge to Those Who Have Not Yet Failed, Journal of Symbolic Computation, vol.18, issue.6, pp.497-501, 1994. ,
DOI : 10.1006/jsco.1994.1061
On the complexity of computing syzygies, Journal of Symbolic Computation, vol.6, issue.2-3, pp.1-13, 1988. ,
DOI : 10.1016/S0747-7171(88)80039-7
Gröbner Bases -A Computational Approach to Commutative Algebra, 1991. ,
Multi-instance security and its application to passwordbased cryptography, pp.312-329 ,
DOI : 10.1007/978-3-642-32009-5_19
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.231.129
The Security of Triple Encryption and a Framework??for??Code-Based??Game-Playing??Proofs, Advances in Cryptology ? EUROCRYPT, pp.409-426, 2004. ,
DOI : 10.1007/11761679_25
QUAD: A multivariate stream cipher with provable security, Journal of Symbolic Computation, vol.44, issue.12, pp.1703-1723, 2009. ,
DOI : 10.1016/j.jsc.2008.10.004
When homomorphism becomes a liability Cryptology ePrint Archive, 2012. ,
(leveled) fully homomorphic encryption without bootstrapping, ITCS, pp.309-325, 2012. ,
DOI : 10.1145/2090236.2090262
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.456.1531
Efficient Fully Homomorphic Encryption from (Standard) LWE, 2011 IEEE 52nd Annual Symposium on Foundations of Computer Science, pp.97-106, 2011. ,
DOI : 10.1109/FOCS.2011.12
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.6463
Ein Algorithmus zum Auffinden der Basiselemente des Restklassenrings nach einem nulldimensionalen Polynomideal, 1965. ,
Gröbner bases: an algorithmic method in polynomial ideal theory, Multidimensional Systems Theory. D, 1985. ,
An algorithm for finding the basis elements of the residue class ring of a zero dimensional polynomial ideal, Journal of Symbolic Computation, vol.41, pp.3-4475, 2006. ,
Chosen-ciphertext attack on noncommutative Polly Cracker. CoRR, abs, p.508015, 2005. ,
Lattice Polly Cracker cryptosystems, Journal of Symbolic Computation, vol.46, issue.5, pp.534-549, 2011. ,
DOI : 10.1016/j.jsc.2010.10.004
URL : http://doi.org/10.1016/j.jsc.2010.10.004
Faster Algorithms for Approximate Common Divisors: Breaking Fully-Homomorphic-Encryption Challenges over the Integers, Pointcheval and Johansson [58], pp.502-519 ,
DOI : 10.1007/978-3-642-29011-4_30
URL : https://hal.archives-ouvertes.fr/hal-00864374
Approximate common divisors via lattices. Cryptology ePrint Archive, Report, vol.437, 2011. ,
DOI : 10.2140/obs.2013.1.271
URL : http://arxiv.org/abs/1108.2714
Fully Homomorphic Encryption over the Integers with Shorter Public Keys, Lecture Notes in Computer Science, vol.6841, pp.487-504, 2011. ,
DOI : 10.1007/978-3-642-22792-9_28
Public key compression and modulus switching for fully homomorphic encryption over the integers, Cryptology ePrint Archive Report, vol.440, 2011. ,
Cryptanalysis of block ciphers with overdefined systems of equations, Advances in Cryptology ? ASIACRYPT 2002, pp.267-287, 2002. ,
Ideals, Varieties, and Algorithms, 2005. ,
Design and Analysis of Practical Public-Key Encryption Schemes Secure against Adaptive Chosen Ciphertext Attack, SIAM Journal on Computing, vol.33, issue.1, pp.167-226, 2003. ,
DOI : 10.1137/S0097539702403773
The membership problem for unmixed polynomial ideals is solvable in single exponential time, Discrete Applied Mathematics, vol.33, issue.1-3, pp.73-94, 1991. ,
DOI : 10.1016/0166-218X(91)90109-A
A survey on Polly Cracker systems, Massimiliano Sala Gröbner Bases. Coding and Cryptography, pp.285-305, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00974896
A new efficient algorithm for computing Gr??bner bases (F4), Journal of Pure and Applied Algebra, vol.139, issue.1-3, pp.61-88, 1999. ,
DOI : 10.1016/S0022-4049(99)00005-5
A new efficient algorithm for computing Gröbner bases without reduction to zero (F5), Proceedings of the 2002 International Symposium on Symbolic and Algebraic Computation, pp.75-83, 2002. ,
Efficient Computation of Zero- Dimensional Gröbner Bases by Change of Ordering, Journal of Symbolic Computation 16, pp.329-344, 1993. ,
Algebraic cryptanalysis of Hidden Field Equation (HFE) cryptosystems using Gröbner bases, Advances in Cryptology ? CRYPTO 2003, 2003. ,
Solving systems of polynomial equations with symmetries using SAGBI-Gröbner bases, ISSAC '09: Proceedings of the 2009 international symposium on Symbolic and algebraic computation, ISSAC '09, pp.151-158, 2009. ,
Combinatorial cryptosystems galore!, Finite Fields: Theory, Applications, and Algorithms, pp.51-61, 1994. ,
DOI : 10.1090/conm/168/01688
A fully homomorphic encryption scheme, 2009. ,
Fully homomorphic encryption using ideal lattices, Proceedings of the 41st annual ACM symposium on Symposium on theory of computing, STOC '09, pp.169-178, 2009. ,
DOI : 10.1145/1536414.1536440
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.362.7592
Fully Homomorphic Encryption without Squashing Using Depth-3 Arithmetic Circuits, 2011 IEEE 52nd Annual Symposium on Foundations of Computer Science, pp.107-109, 2011. ,
DOI : 10.1109/FOCS.2011.94
Implementing Gentry???s Fully-Homomorphic Encryption Scheme, Advances in Cryptology ? EUROCRYPT 2010, pp.129-148, 2011. ,
DOI : 10.1007/978-3-642-20465-4_9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.6183
Better Bootstrapping in Fully Homomorphic Encryption, Public Key Cryptography ? PKC 2012, 2012. ,
DOI : 10.1007/978-3-642-30057-8_1
Homomorphic Evaluation of the AES Circuit, pp.850-867 ,
DOI : 10.1007/978-3-642-32009-5_49
A well-characterized approximation problem, [1993] The 2nd Israel Symposium on Theory and Computing Systems, pp.301-305, 1993. ,
DOI : 10.1109/ISTCS.1993.253463
Polly Cracker, Revisited, Revisited, Public Key Cryptography ? PKC 2012, pp.17-33 ,
DOI : 10.1007/978-3-642-30057-8_2
Algebraic aspects of cryptography, 1998. ,
DOI : 10.1007/978-3-662-03642-6
Gröbner-bases, Gaussian elimination and resolution of systems of algebraic equations, Proceedings of the European Computer Algebra Conference on Computer Algebra, 1983. ,
Better Key Sizes (and Attacks) for LWE-Based Encryption, Lecture Notes in Computer Science, vol.66, issue.6, pp.319-339, 2011. ,
DOI : 10.1007/3-540-45708-9_19
On ideal lattices and learning with errors over rings, Advances in Cryptology ? EUROCRYPT 2010, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00921792
Additively Homomorphic Encryption with d-Operand Multiplications, Advances in Cryptology ? CRYPTO 2010, pp.138-154, 2010. ,
DOI : 10.1007/978-3-642-14623-7_8
Lattice-based cryptography, Post-Quantum Cryptography, pp.147-191, 2009. ,
De Nugis Groebnerialium 2: Applying Macaulay's Trick in Order to Easily Write a Gr??bner Basis, Applicable Algebra in Engineering, Communication and Computing, vol.13, issue.6, pp.437-446, 2003. ,
DOI : 10.1007/s00200-002-0112-2
Can homomorphic encryption be practical?, Proceedings of the 3rd ACM workshop on Cloud computing security workshop, CCSW '11, pp.113-124, 2011. ,
DOI : 10.1145/2046660.2046682
A Framework for Efficient and Composable Oblivious Transfer, Advances in Cryptology ? CRYPTO 2008, pp.554-571, 2008. ,
On lattices, learning with errors, random linear codes, and cryptography, Journal of the ACM, vol.5634, pp.1-3440, 2009. ,
The learning with errors problem, IEEE Conference on Computational Complexity 2010, pp.191-204, 2010. ,
Homomorphic Encryption: From Private-Key to Public-Key, Lecture Notes in Computer Science, vol.6597, pp.219-234, 2011. ,
DOI : 10.1007/978-3-642-19571-6_14
Estimating the security of lattice-based cryptosystems. Cryptology ePrint Archive, Report, vol.137137, 2010. ,
Fully homomorphic encryption with relatively small key and ciphertext sizes, Public Key Cryptography, pp.420-443, 2010. ,
The Sage Development Team, 2011. ,
On the Complexity of Matrix Multiplication, 2010. ,
Fully Homomorphic Encryption over the Integers, Gilbert [46], pp.24-43 ,
DOI : 10.1007/978-3-642-13190-5_2
Modern computer algebra, 2003. ,
Multiplying matrices faster than Coppersmith-Winograd, STOC, pp.887-898, 2012. ,
Minimal achievable approximation ratio for MAX-MQ in finite fields, Theor. Comput. Sci, vol.410, pp.21-232285, 2009. ,
