An Introduction to SICONOS INRIA, Rhône-Alpes, Tech. Rep. RR-0340 Available: http:// hal.inria.fr/inria-00162911, 2007. ,
Numerical Methods for Nonsmooth Dynamical Systems, ser. Lecture Notes in Applied and Computational Mechanics, 2008. ,
The Dynamics of Discrete Mechanical Systems with Perfect Unilateral Constraints, Archive for Rational Mechanics and Analysis, vol.154, issue.3, pp.199-274, 2000. ,
DOI : 10.1007/s002050000105
URL : https://hal.archives-ouvertes.fr/hal-00111308
Formulation and well-posedness of the dynamics of rigid-body systems with perfect unilateral constraints, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.359, issue.1789, pp.2327-2346, 2001. ,
DOI : 10.1098/rsta.2001.0854
Tracking Control for Hybrid Systems With State-Triggered Jumps, IEEE Transactions on Automatic Control, vol.58, issue.4, pp.876-890, 2013. ,
DOI : 10.1109/TAC.2012.2223351
A passivity approach to controller-observer design for robots, IEEE Transactions on Robotics and Automation, vol.9, issue.6, pp.740-754, 1993. ,
DOI : 10.1109/70.265918
URL : http://doc.utwente.nl/15045/1/passivity_approach_-_berghuis.pdf
Global output feedback tracking control for a class of Lagrangian systems, Automatica, vol.38, pp.1915-1921, 2002. ,
Absolute stability and the Lagrange???Dirichlet theorem with monotone multivalued mappings, Systems & Control Letters, vol.51, issue.5, pp.343-353, 2004. ,
DOI : 10.1016/j.sysconle.2003.09.007
URL : https://hal.archives-ouvertes.fr/inria-00071792
Observer Design for Lur'e Systems With Multivalued Mappings: A Passivity Approach, IEEE Transactions on Automatic Control, vol.54, issue.8 ,
DOI : 10.1109/TAC.2009.2023968
URL : https://hal.archives-ouvertes.fr/hal-00756302
BV periodic solutions of an evolution problem associated with continuous moving convex sets, Set-Valued Analysis, vol.109, issue.2, pp.381-399, 1995. ,
DOI : 10.1007/BF01026248
The Linear Complementarity Problem, 2009. ,
A sweeping process approach to inelastic contact problems with general inertia operators, European Journal of Mechanics - A/Solids, vol.26, issue.3, pp.474-490, 2007. ,
DOI : 10.1016/j.euromechsol.2006.07.002
A convergence result for a vibro-impact problem with??a??general inertia operator, Nonlinear Dynamics, vol.2, issue.2, pp.361-384, 2009. ,
DOI : 10.1007/978-3-0348-7614-8
URL : https://hal.archives-ouvertes.fr/hal-01552482
Follow the Bouncing Ball: Global Results on Tracking and State Estimation With Impacts, IEEE Transactions on Automatic Control, vol.58, issue.6, pp.1470-1485, 2013. ,
DOI : 10.1109/TAC.2013.2237952
Observer-based control of linear complementarity systems, International Journal of Robust and Nonlinear Control, vol.50, issue.5, pp.1193-1218, 2011. ,
DOI : 10.1016/0024-3795(83)90062-9
URL : https://hal.archives-ouvertes.fr/hal-00834580
Fundamental Inequalities for Discrete and Discontinuous Functional Equations, Journal of the Society for Industrial and Applied Mathematics, vol.12, issue.1, pp.43-57, 1964. ,
DOI : 10.1137/0112004
An introduction to Moreau's sweeping process, " in Impacts in Mechanical Systems: Analysis and Modelling B. Brogliato, Lecture Notes in Physics, vol.551, pp.1-60, 2000. ,
A unified variational model for the dynamics of perfect unilateral constraints, European Journal of Mechanics - A/Solids, vol.17, issue.5, pp.819-842, 1998. ,
DOI : 10.1016/S0997-7538(98)80007-7
Velocity observers for non-linear mechanical systems subject to non-smooth impacts, Automatica, vol.38, issue.12, pp.2169-2175, 2002. ,
DOI : 10.1016/S0005-1098(02)00164-4
Trajectory Tracking Control of Multiconstraint Complementarity Lagrangian Systems, IEEE Transactions on Automatic Control, vol.55, issue.6, pp.1300-1313, 2010. ,
DOI : 10.1109/TAC.2010.2042231
URL : https://hal.archives-ouvertes.fr/hal-00756307
Liaisons unilatérales sans frottement et chocs inélastiques, C. R. Acad. Paris Sér. II Méc. Phys. Chim. Sci. Univers Sci. Terre, vol.296, issue.19, pp.1473-1476, 1983. ,
Unilateral Contact and Dry Friction in Finite Freedom Dynamics, CISM Courses and Lectures, International Centre for Mechanical Sciences, pp.1-82, 1988. ,
DOI : 10.1007/978-3-7091-2624-0_1
A chain rule involving vector functions of bounded variation, Journal of Functional Analysis, vol.74, issue.2, pp.333-345, 1987. ,
DOI : 10.1016/0022-1236(87)90029-2
Robot control by using only joint position measurements, IEEE Transactions on Automatic Control, vol.35, issue.9, pp.1058-1061, 1990. ,
DOI : 10.1109/9.58537
Adaptive motion control of rigid robots: A tutorial, Automatica, vol.25, issue.6, pp.877-888, 1989. ,
DOI : 10.1016/0005-1098(89)90054-X
Dissipative Design of Observers for Multivalued Nonlinear Systems, Proceedings of the 45th IEEE Conference on Decision and Control, pp.5400-5405, 2006. ,
DOI : 10.1109/CDC.2006.377335
CONTINUOUS DEPENDENCE ON DATA FOR VIBRO-IMPACT PROBLEMS, Mathematical Models and Methods in Applied Sciences, vol.359, issue.01, pp.53-93, 2005. ,
DOI : 10.1098/rsta.2001.0859
A proximal-like method for a class of second order measure-differential inclusions describing vibro-impact problems, Journal of Differential Equations, vol.250, issue.1, pp.476-514, 2011. ,
DOI : 10.1016/j.jde.2010.10.010
URL : https://hal.archives-ouvertes.fr/hal-01566931
A Numerical Scheme for Impact Problems I: The One-Dimensional Case, SIAM Journal on Numerical Analysis, vol.40, issue.2, pp.702-768, 2002. ,
DOI : 10.1137/S0036142900378728
Semi-global observer for multi-output nonlinear systems, Systems & Control Letters, vol.42, issue.3, pp.233-244, 2001. ,
DOI : 10.1016/S0167-6911(00)00098-0
Hybrid-type observer design based on a sufficient condition for observability in switched nonlinear systems, International Journal of Robust and Nonlinear Control, vol.42, issue.11, pp.1064-1089, 2014. ,
DOI : 10.1080/00207721.2010.543494
Observer Design for Frictionless and Unilaterally Constrained Mechanical Systems: A Passivity-Based Approach Full report Available: https://hal.inria.fr/hal-01113344v2, Simulation gallery ,
DOI : 10.1109/tac.2015.2492098
Stability and Observer Design for Lur'e Systems with Multivalued, Nonmonotone, Time-Varying Nonlinearities and State Jumps, SIAM Journal on Control and Optimization, vol.52, issue.6, pp.3639-3672, 2014. ,
DOI : 10.1137/120902252
URL : https://hal.archives-ouvertes.fr/hal-01083629
Stability notions for a class of nonlinear systems with measure controls, Mathematics of Control, Signals, and Systems, vol.4, issue.4, pp.245-275, 2015. ,
DOI : 10.1016/S1468-1218(02)00084-6
URL : https://hal.archives-ouvertes.fr/hal-01074144
Observability implies observer design for switched linear systems, Proceedings of the 14th international conference on Hybrid systems: computation and control, HSCC '11, pp.3-12, 2011. ,
DOI : 10.1145/1967701.1967705
Observability for Switched Linear Systems: Characterization and Observer Design, Proc. 51st IEEE Conf. Decision Control, pp.891-904, 2012. ,
DOI : 10.1109/TAC.2012.2224257
An observer for switched differentialalgebraic equations based on geometric characterization of observability, Proc. 52nd IEEE Conf. Decision Control, pp.5981-5986, 2013. ,
A discontinuous output feedback controller and velocity observer for nonlinear mechanical systems, Automatica, vol.40, issue.4, pp.695-700, 2004. ,
DOI : 10.1016/j.automatica.2003.12.007
