Conference papers
Large displacement body-fitted FSI simulations using a mesh-connectivity-change moving mesh strategy
Nicolas Barral 1 Frédéric Alauzet 1
1 Gamma3 - Automatic mesh generation and advanced methods
Inria Paris-Rocquencourt, ICD - Institut Charles Delaunay
Abstract : This paper deals with numerical simulations involving three-dimensional moving geometries with large displacements. Such simulations are much valued by industries, but remain very time-consuming. A robust moving mesh algorithm coupling an elasticity-like mesh deformation solution and mesh optimizations is proposed, that allows to avoid remeshing while performing large displacements. However, this is done at the cost of relaxing the fixed-topology constraint imposed by the classical Arbitrary-Lagrangian-Eulerian (ALE) framework. An ALE compressible flow solver is integrated to this process. This solver lies on the strict interpretation of the Discrete Geometrical Conservation Law to preserve the order of accuracy of the time integration. For fluid-structure interaction (FSI) simulations, the six degrees of freedom (6-DOF) approach for rigid bodies is considered. Finally, 3D imposed-motion and FSI examples are given, to validate the proposed approach
Keywords : ALE moving mesh
Complete list of metadata
https://hal.inria.fr/hal-01113351
Contributor : Nicolas Barral Connect in order to contact the contributor
Submitted on : Thursday, February 5, 2015 - 10:24:29 AM
Last modification on : Friday, January 21, 2022 - 3:19:31 AM
Identifiers
Collections
Citation
Nicolas Barral, Frédéric Alauzet. Large displacement body-fitted FSI simulations using a mesh-connectivity-change moving mesh strategy. 44th AIAA Fluid Dynamics Conference, Jun 2014, Atlanta, United States. ⟨10.2514/6.2014-2773⟩. ⟨hal-01113351⟩
Share
Metrics
Record views
128
