Conference papers
Multigrid Strategies Coupled with Anisotropic Mesh Adaptation
Victorien Menier 1 Adrien Loseille 1 Frédéric Alauzet 1
1 Gamma3 - Automatic mesh generation and advanced methods
Inria Paris-Rocquencourt, ICD - Institut Charles Delaunay
Abstract : This paper is an attempt to combine a full multigrid (FMG) algorithm with the classical anisotropic mesh adaptation loop. The FMG algorithm aims at improving the convergence rate of the flow solver, while mesh adaptation tends to improve the tradeoff between CPU time and accuracy of the solution. Coupling these two methods consists, at each stage of the adaptation loop, in running a multigrid simulation using the previously adapted coarser meshes. The main benefits of this coupling are that (i) the convergence of mesh adapta-tion is improved thanks to the properties stated by the FMG theory, and (ii) anisotropic coarsening is automatically handled by mesh adaptation. First, the implementation and the validation of the multigrid procedures are described, and then the coupling is detailed. Results are presented in 2D and 3D for various flow prescriptions, including a real-life configuration.
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-01113357
Contributor : Victorien Menier Connect in order to contact the contributor
Submitted on : Thursday, February 5, 2015 - 10:36:27 AM
Last modification on : Friday, January 21, 2022 - 3:16:02 AM
Long-term archiving on: : Wednesday, May 6, 2015 - 10:15:46 AM
File
aiaa2015.pdf
Identifiers
Collections
Citation
Victorien Menier, Adrien Loseille, Frédéric Alauzet. Multigrid Strategies Coupled with Anisotropic Mesh Adaptation. AIAA Scitech 2015, Jan 2015, Kissimmee, United States. ⟨10.2514/6.2015-2041⟩. ⟨hal-01113357⟩
Share
Metrics
Record views
125
Files downloads
292
