On Hills and Dales, Philosophical Magazine, vol.440, pp.421-427, 1870. ,
DOI : 10.1017/CBO9780511710377.018
Nouvelles observations sur les lignes de fa??tesfa??tes et de thalweg, Comptes Rendus des Séances de l'Académie des Sciences, pp.1023-1025, 1872. ,
Use of watersheds in contour detection, Procs. of the International Workshop on Image Processing Real-Time Edge and Motion Detection/Estimation, 1979. ,
Un algorithme optimal de ligne de partage des eaux, Procs. of 8` eme Congrès AFCET, pp.847-859, 1991. ,
Watersheds in digital spaces: an efficient algorithm based on immersion simulations, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.6, pp.583-598, 1991. ,
DOI : 10.1109/34.87344
The morphological approach to segmentation: the watershed transformation, Mathematical Morphology in Image Processing, pp.443-481, 1993. ,
Topological grayscale watershed transform, Procs. of SPIE Vision Geometry V, pp.136-146, 1997. ,
On Topological Watersheds, Journal of Mathematical Imaging and Vision, vol.34, issue.6, pp.217-230, 2005. ,
DOI : 10.1007/s10851-005-4891-5
URL : https://hal.archives-ouvertes.fr/hal-00622398
Quasi-Linear Algorithms for the Topological Watershed, Journal of Mathematical Imaging and Vision, vol.13, issue.6, pp.231-249, 2005. ,
DOI : 10.1007/s10851-005-4892-4
URL : https://hal.archives-ouvertes.fr/hal-00622399
Watersheds, mosaics, and the emergence paradigm, Discrete Applied Mathematics, vol.147, issue.2-3, pp.301-324, 2005. ,
DOI : 10.1016/j.dam.2004.09.017
URL : https://hal.archives-ouvertes.fr/hal-00622113
Minimum Spanning Forests for Morphological Segmentation, Procs. of the second international conference on Mathematical Morphology and its Applications to Image Processing, pp.77-84, 1994. ,
DOI : 10.1007/978-94-011-1040-2_11
The image foresting transform: theory, algorithms, and applications, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.1, pp.19-29, 2004. ,
DOI : 10.1109/TPAMI.2004.1261076
The Ordered Queue and the Optimality of the Watershed Approaches, Procs. of the 5th International Symposium on Mathematical Morphology, pp.341-350, 2000. ,
DOI : 10.1007/0-306-47025-X_37
Fuzzy Connectedness and Object Definition: Theory, Algorithms, and Applications in Image Segmentation, Graphical Models and Image Processing, vol.58, issue.3, pp.246-261, 1996. ,
DOI : 10.1006/gmip.1996.0021
Relative Fuzzy Connectedness among Multiple Objects: Theory, Algorithms, and Applications in Image Segmentation, Computer Vision and Image Understanding, vol.82, issue.1, pp.42-56, 2001. ,
DOI : 10.1006/cviu.2000.0902
Digital topology: Introduction and survey, Computer Vision, Graphics, and Image Processing, vol.48, issue.3, pp.357-393, 1989. ,
DOI : 10.1016/0734-189X(89)90147-3
Topographic distance and watershed lines, Signal Processing, vol.38, issue.1, pp.113-125, 1993. ,
DOI : 10.1016/0165-1684(94)90060-4
Watershed of a continuous function, Signal Processing, vol.38, issue.1, pp.68-86, 1993. ,
DOI : 10.1016/0165-1684(94)90059-0
URL : https://hal.archives-ouvertes.fr/hal-00622129
An Efficient Algorithm for Drainage Network Extraction on DEMs, Journal of Visual Communication and Image Representation, vol.5, issue.2, pp.181-189, 1994. ,
DOI : 10.1006/jvci.1994.1017
The watershed transform: Definitions, algorithms and parallelization strategies, Fundamenta Informaticae, vol.41, issue.12, pp.187-228, 2001. ,
The drop of water principle: comparison of classical watershed algorithms ,
Otakar Bor??vka on minimum spanning tree problem Translation of both the 1926 papers, comments, history, Discrete Mathematics, vol.233, issue.1-3, pp.3-36, 2001. ,
DOI : 10.1016/S0012-365X(00)00224-7
Shortest connection networks and some generalizations, Bell Syst, Tech. J, vol.36, pp.1389-1401, 1957. ,
DOI : 10.1002/j.1538-7305.1957.tb01515.x
On the History of the Minimum Spanning Tree Problem, IEEE Annals of the History of Computing, vol.7, issue.1, pp.43-57, 1985. ,
DOI : 10.1109/MAHC.1985.10011
Graph-theoretical methods for detecting and descibing gestalt clusters, IEEE Transactions on Computers C, vol.20, issue.1, pp.99-112, 1971. ,
Introduction to algorithms, 2001. ,
A minimum spanning tree algorithm with inverse-Ackermann type complexity, Journal of the ACM, vol.47, issue.6, pp.1028-1047, 2000. ,
DOI : 10.1145/355541.355562
Parallel watershed algorithm based on sequential scanning, Procs. of IEEE Workshop on Nonlinear Signal and Image Processing, 1995. ,
Grayscale Watersheds on Perfect Fusion Graphs, Procs. of the 11th International Workshop on Combinatorial Image Analysis, pp.60-73, 2006. ,
DOI : 10.1007/11774938_6
URL : https://hal.archives-ouvertes.fr/hal-00622038
Duality between the Watershed by Image Foresting Transform and the Fuzzy Connectedness Segmentation Approaches, 2006 19th Brazilian Symposium on Computer Graphics and Image Processing, pp.53-60, 2006. ,
DOI : 10.1109/SIBGRAPI.2006.14
On the dynamics, Image and Vision Computing to appear ,
On connectivity properties of grayscale pictures, Pattern Recognition, vol.16, issue.1, pp.47-50, 1983. ,
DOI : 10.1016/0031-3203(83)90007-9
Relative fuzzy connectedness and object definition: theory, algorithms, and applications in image segmentation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.11, pp.1485-1500, 2002. ,
DOI : 10.1109/TPAMI.2002.1046162
Fusion graphs: merging properties and watershed, submitted. Also in technical report, pp.2005-2009, 2006. ,
DOI : 10.1007/s10851-007-0047-0
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.219.1082
Fusion Graphs, Region Merging and Watersheds, Procs. of the 13th International Conference on Discrete Geometry for Computer Imagery, pp.343-354, 2006. ,
DOI : 10.1007/11907350_29
URL : https://hal.archives-ouvertes.fr/hal-00622035
Scale-Based Fuzzy Connected Image Segmentation: Theory, Algorithms, and Validation, Computer Vision and Image Understanding, vol.77, issue.2, pp.145-174, 2000. ,
DOI : 10.1006/cviu.1999.0813
Vectorial scale-based fuzzy-connected image segmentation, Computer Vision and Image Understanding, vol.101, issue.3, pp.177-193, 2006. ,
DOI : 10.1016/j.cviu.2005.07.009
Using Canny's criteria to derive a recursively implemented optimal edge detector, International Journal of Computer Vision, vol.1, issue.2, pp.167-187, 1987. ,
DOI : 10.1007/BF00123164
An overview of morphological filtering, Circuits Systems Signal Process, vol.11, issue.1, pp.48-107, 1992. ,
Attribute Openings, Thinnings, and Granulometries, Computer Vision and Image Understanding, vol.64, issue.3, pp.377-389, 1996. ,
DOI : 10.1006/cviu.1996.0066
Building the Component Tree in Quasi-Linear Time, IEEE Transactions on Image Processing, vol.15, issue.11, pp.3531-3539, 2006. ,
DOI : 10.1109/TIP.2006.877518
URL : https://hal.archives-ouvertes.fr/hal-00622110
Morphological Image Analysis, 1999. ,
Minimum spanning tree by watershed in preparation ,
Geodesic saliency of watershed contours and hierarchical segmentation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.18, issue.12, pp.1163-1173, 1996. ,
DOI : 10.1109/34.546254
URL : https://hal.archives-ouvertes.fr/hal-00622128
We will prove that for any point x 0 in V , there exists in X a path from x 0 to M (F ) which is a path with steepest descent for F . Thus, by Lem. 9, this will establish the first part of Prop. 13. From Lem. 9, it may be seen that there exists in X an M-path (for H), denoted by ? = x 0 , . . . , x l , which is a path with steepest descent for H. By Lem. 42.ii, ? is a path with steepest descent for F . Since x l is a vertex of M (H), by Lem. 42.i, there exists in M (H) a path ? ? = x l , . . . , x m from x l to M (F ) which is a path with steepest descent for F . Since X is an extension of, M (H) ? X. Hence ,
P i?1 ) holds. By Prop. 18 and Lem. 41, (P i?1 ) implies that X i?1 is a forest relative to M (F ) Therefore, it follows from Lem. 45, that the altitude (for F ) of any edge of G outgoing from X i?1 is greater than or equal to F (u i ) By construction of F i?1 ,
Suppose that Y is a MSF relative to X. Suppose also that there exist A and B, two components of X such that ,
) and such that x k (resp. x l ) is the only vertex of A ? (resp. B ? ) in ?. Notice that {x k , x k+1 } and {x l?1 , x k (resp. ? B = x l , . . . , x m ) be a simple path in A ? (resp. B ? ), such that x 0 (resp. x m ) is the only point of ? A (resp. ? B ) which is a point of A (resp. B) Since ? ? = x 0 Without loss of generality, Thus, since F (?) < F (A, B), we have either F (? A ) ,
